thermostat not opening..what happens to intake water?
 skennelly
                    Member Posts: 2,196 ✭✭✭✭
skennelly
                    What happens to the intake water when the thermostat doesn't open?  Does it just bypass the engine and exit the exhaust?
out via the exhaust
I've read white smoke is related to head gasket...please no. I did check the oil and it was clean.
The biggest indicator of bad head gaskets is not only temperature, but wild fluctuation of temperatures.. 220 is spooky. 220 to 170 to 220 to 190 to 220 in a ten second window is more than spooky. If you rev engine and it goes down in temperature, its time to look at your circ pumps impeller.. If it rises in temp when you rev, gaskets are most likely.
The good news is neither are that bad to repair if you catch it in time.. Both can be done engine in boat an an afternoon.
Sometimes, it's just the way it is in a raw water engine, if the engines water pump isn't fairly new or lubricated, they freeze. Its easy to see bad pump on a car as it has that great silly clutch fan hanging off front and any wear in seal will be readily evident... On a boat its harder to spot.
But more likely yet? You simply aren't moving enough water at extended idle to cool the engine.
Here's what I found today
Is there two pumps on a Closed loop system?
And still hoping there isn't any further damage from the high temps.
This is a huge reason why I like having vesselview. It gives me water pressure status coming from the pump. Being I keep my boat on the lift, it has to prime each weekend when I put it in (not a big issue, but just worth noting). I watch it each time I start the engines, and yes, I'm a bit paranoid about it. Heck, I've seen it drop while up on plane and pulled it off plane even before the alarm went off. It was an engine hose that came off that time.
& as far as loosen engine hose, I have something even simpler. Just loosen the blue engine plug on the output and/or input of pump before you even start up.
