mercathode
rasbury
Member Posts: 8,971 ✭✭✭✭✭
I was just reading an article about the mercathode system and it states that it will kill your battery if you do not keep it on a charger...never thought of that!
Could be something PO did, but my single screw boat has two MerCathode units, one mounted on the backside of the engine, attached to the engine, and one mounted on the transom, attached to the outside. There's a couple goofy round "thingies" on the transom connected to the "brain" boxes.
@Dude_Himself the older style Mercathode system used a round puck looking thing as the anodes that were mounted on either side of the transom, usually on the Alpha drives. Sounds like the PO went that route. Some info here: http://www.sterndrives.com/merc/driveparts/MERCATHODE KIT.html
And here is some good info and mounting instructions for the newer units. I might have even seen this someplace here in the archives:
http://www.boatfix.com/merc/servmanl/14/14a7.pdf
Down towards the bottom of the document there is also some excellent trouble shooting info for corrosion issues.
In either case, I am now wondering again about the question of does, or doesn't it draw power when not in the water.
To be on the safe side, when I install my batteries later today I think I'll just disconnect the Mercathode controller, will just have to remember to re-connect when splash time comes. IF it ever does....bloody cold weather....
