thermostat not opening..what happens to intake water?
2»
  • aero3113aero3113 Member Posts: 9,623 ✭✭✭✭✭
    Is this something that's usually replaced with an outdrive and bellows service?
    With an Alpha drive, most likely. On the Alpha the pump is in the drive, Bravo has the pump on the engine.
  • thepriceisrightthepriceisright Member Posts: 92 ✭✭
    Got it. Thanks!
    edited April 2018
    You know that stupid little rubber impeller was the driving force that got me started on doing my own repairs.  My last boat was a 24 ft bowrider with the same Merc 350 MPI's that i have in my Rinker.  i paid a mechanic to do a tune up and replace the impeller.  Took it out for a spin the next week just to have it overheat at the loading ramp.  Took it back to him to "Fix". For him to tell me nothing was wrong.  Next week, same thing.  Took it home, ordered a new impeller and decided to do it myself.  Found out that some of the impellers out there are cheaper for a reason.  That one just wouldn't prime.
    I agree with you about the OMC but one thing it was easy to change
    Impeller change went well.  Though I look and feel like I was attacked by a mountain lion.  Every part of me is scratched up.
    Broke impeller pieces were caught around the first oil cooler.  Used a shop vac to suck them out.
    edited April 2018
    Rule # one before changing impeller, take Advil before and after you began the work. Rule #2 have immediate strong beverage after completion.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,846 mod
    I changed out my genny impeller on Friday (along with the yellow shaft piece behind it).  I changed out an impeller for a friend on his Rinker 350 engine (for some reason he does one engine each year).  I was surprised that you cannot flip the wear plate to use again.
