Vessel View Mobil
anyone familiar with the vessel view mobil install. I hooked this up both lights blink when the key is turned on I entered the serial # for the motor when I try to connect it gives me a error that says unable to complete setup ,key all engine and try again I have a 270 single engine Thanks
Here is some fun reading for you. Lots of good info in this thread including diagrams on how to hookup twin and single setups.
https://rinkerboats.vanillaforums.com/discussion/comment/60945#Comment_60945
Like the picture.
Thanks all
I guess Ill hunt down a yellow terminator
I knew if I posted the question here I would have better results getting a answer than anywhere else .
I still have mine as well, but I only use my vesselview. There was someone on my dock that wanted the VV mobile (although the admiral said I should feel weird about selling something I got for free).
mobile view works great if you have a single engine.
with Twins you either have to move the module from engine to engine lol
For Twin setup your basically a screen away from having a dash mounted system
That is incorrect. It will work on twin engines without having to move from one to the other.
Dude, if you turn the key all the way to the on position, it will update with faults on VesselView. (Oh, that's what Stodge just said too)
One unit, plugged into the correct spot will indeed show both engines. I have the digital throttle and have a connection in my dash. I can connect it there and it will show both engines. I've also connected in my engine room, on one engine, and yes, it does show both engines. I've done this and so have others on my dock. We were trying to test the Bluetooth range. Worked fine in both places and showed both engines. Maybe you did not have a setting correct? Now, as far as splitters and such needed, that is possible on some boats, but I know for sure those with DTS will work fine as is.
throttle by wire yes u can get away with it
