what could be causing our 342 taking in water in the transom?
thewildcallsthewildcalls Member Posts: 8
please respond our boat was put in and taken out very quickly because it was taking in water. 2006 342
Best Answer
  • rasburyrasbury Member Posts: 8,965 ✭✭✭✭✭
    You have to provide a lot more info to even start to guess...new to you boat? Had the boat for years but a new problem?
  • raybo3raybo3 Administrator Posts: 5,615 admin
    How much water is it taking on????? You may have a transom bracket problem. Take a look behind your engines at the transom bracket and see if its leaking. If so sorry to say its a big job. Engine has to come out. Once the engine is out hopefully you dont have fiberglass damage. I had to do both of mine over the last few years. Good luck and keep us posted.
  • aero3113aero3113 Member Posts: 9,864 ✭✭✭✭✭
    Hopefully it’s just the rubber bellows that needs to be replaced.
  • thewildcallsthewildcalls Member Posts: 8
    All I know is we are so bummed out. The mechanics are looking at it this week.
    Thanks everyone for all the comments. Will keep you posted
