what could be causing our 342 taking in water in the transom?
please respond our boat was put in and taken out very quickly because it was taking in water. 2006 342
Best Answer
Black_Diamond Member Posts: 5,439 ✭✭✭✭✭
Lots of possibilities! Blige drain plug in? BTW the bilge drain plug housing can leak around the edges: pull and reseal (had the issue on mine).
Water coming in that fast (as it sounds) think thru hulls, gen set strainer, hoses to raw water pump.Past owner of a 2003 342FV
