TV Mount Above Aft
Anyone have experience mounting a TV above the Aft opposite the helm on a 342 where they did on the 06 and later models? I purchased a 24" Samsung and an articulating arm but not sure how to mount or access rear of that area without removing the entire helm cabinet? Since it is not 12v is do I need an inverter or can I simply extend the cord to plug into the existing outlet in the current TV cabinet. I have an 05' so the box TV isn't cutting it. Thanks for your help.
I put a 26 inch in the spot I think you're talking about. I used a fixed mount instead of an arm, but an arm should work. I had to remove the switch panel on the helm and have a friend hold a box wrench with a nut while I tightened a screw from the inside. It's a tight spot to be sure and you'll want a helper with skinny arms and good dexterity.
Use a digital multi-meter to measure the voltage. You should have 12VDC between the red and black wire. But, before using them, you need to figure out what it is fused/breakered at. If the wires are thin and fused at a lower amperage, it wouldn't be good to use.
A lot of Samsungs run off of 19V. Does the power cord have an inverter built in, or is it in the TV?
It runs on 12v using an external adapter, so I was able to just wire up a direct 12v connection to the TV.
One word of caution: sometimes the product in the box has an internal converter rather than the 12v plug. You'll want to open the box at the store to check before leaving. There is no way to tell by just looking at the box.
