350 MAG high output alternator
69fastback
Member Posts: 951 ✭✭✭
Does anyone other than Mechman make a high output alternator (170 amps or higher) for the 350 Mag, that is a direct bolt on? I have a KXMA 1200.1 and KXMA 800.8 that were sharing a 4 gauge power supply before, and have now been properly rewired using 4 gauge for each amp, and the sub configuration was changed from one drawing 600 RMS, to now 2 drawing 600 each. This has obviously greatly exceeded the capacity of the charging system, and is causing the sub amp to hit the low voltage cutoff with anything over about 3/4 volume. Currently it has 2 850 CCA deep cycle batteries, and I'm about to put the largest blue tops in it, but using OHMs law (POWER = VOLTAGE x CURRENT), I really need a 200ish amp alternator to provide the proper power to the amps, and power the rest of the boat. 170 would really probably be okay, as that comes out to 2380 to power the whole boat, and that's just using 14 volts, but it's better to have a little extra since you won't typically see a full 14.4 (or sometimes even 14) volts at the battery. What options are out there for a higher output alternator?
This discussion has been closed.
I thought for sure that Hardin Marine would have one, but their biggest is 120 amps. Take a look at Power Bastards.
I found a local shop that will rebuild mine to get the output I need.
Do you have an onboard battery charger that runs on shore power? If yes, you probably have an isolator too. The alternator and charger will be connected to the isolator, and the isolator will connect to the batteries.
The fact of the matter is, I’m not reinventing anything here. This is being done in boats across the country. It works, and it’s not a fire hazard,
These batteries make it happen.
https://4xspower.com/shop/xp-series/xp-series-batteries/xp3000/
Everything in the boat that needs to be addressed has been addressed. All I asked was if anyone made a high output alternator, other than Mechman, that’s a direct fit replacement. As I pointed out, literally not one reply has been to answer the only question I asked. I appreciate the help from al, Larae, and you. The worthless childish remarks from others, I think everyone can do without, and I’m sure you can understand the frustration it causes when I have to sit here and explain myself repeatedly with no answer to the very specific question I asked.
