Tow vehicle
danfingerlakesny
                    Member Posts: 4 ✭
                    Hello to all!
The wife and I are the proud new owners of a beautiful 2001 Rinker Captiva 232! She's more boat than we've ever had before...ALOT more! A 190 Larson All American being the largest prior.
I saw this boat and just had to have it! As our season approaches I'm beginning to worry if our 2015 Honda Pilot can handle her. The HP is rated at 4500lbs. We trailer most weekends about 14 miles roundtrip to the launch. It's primarily the launch that is starting to worry me...not the to and fro. Maybe I've been watching too many "boat launch fails" videos...but I refuse to be "that guy" at the launch with my wife's HP submerged! Does anyone have any thoughts on this? Am I being paranoid or do I have a serious concern??? Thx for any input.
http://rinkerboats.vanillaforums.com/discussion/8405/trailer-for-280-express-cruiser#latest
the first time you're overly anxious to launch/recover and attempt anything short of finesse, you're going to have a bad day. with a truck designed even for marginal towing (and at proper weight), you can brute force it without worry... there are times when this is necessary and they aren't something you can anticipate... that pilot will not brute force that boat.
I'd throw EoH brakes on the trailer, get a good brake controller for the Pilot, make sure the boat is set up properly on the trailer, then enjoy myself. The trailer brakes could be used to prevent the tail from wagging the dog, or pulling it backwards into the water on a slick ramp.
Regarding brakes on the Pilot: the parking brake is more than adequate to hold both on the ramp. Set the parking brake, put the car in Neutral, and slowly let off the brakes until the load is resting on the parking brake. Then shift into park.
10 percent east of Rockies, 20 percent west. Thats the officially accepted buffer between what you hook up to and what your rating is that will keep you out of trouble of all kinds.
My new old rig is a standard... Four speed... Not because I dont trust my clutch foot, but because its too easy not to do, I have plastic wheel chocks with a line tied to them that is four feet long- far too short to reach trailer tires... I set them on the ramp while launching and retrieving, and drag them behind me while pulling forward until I'm out of the way enough to grab them and flip them into the bed.
My opinion after a few months of research and nearly making a purchase myself: if your vehicle/boat needs a WD system your vehicle is probably not adequate, or your boat/trailer isn't set up properly.
I regularly tow 10k lbs with a Ford E350 extended 15 passenger van. I've towed in thunder storms and strong winds, through WV mountains, and over I-95 in NC/SC (where it's just 20' sections of poorly aligned concrete that make the vehicle bounce for 110 miles straight. Only time I felt like I needed WD it's because the boat wasn't set properly on the trailer after adjusting the winch post. Boat was actually about 1' forward of where it should have been, and that increased the tongue weight.
Venture also says NO siting the incompatibility with surge brakes. I know there's some surge-brake-compatible WD systems (Equalizer, Reese).
There's also several experts that state the WD load puts undue stress on a single pole trailer, effectively doubling to quadrupling the load placed on the pole (it's the difference in load between the front and rear axles, multiplied by the leverage generated by (the difference in distance between the front and rear axles in relation to the difference in load and distance between the rear axle of the vehicle and the center axle or midway between the two axles of the trailer).
