canceled my launch date
13»
    edited May 2018
  • rasburyrasbury Member Posts: 8,691 ✭✭✭✭✭
    That looks like the very bottom- if it is around one of the bolts then it might be leaking. That seal around the gimbal is not a durable design...
    Yep bottom of the inner plate was just finishing the Gimble ring project just needed to put the drive back on a few minor things I’ll put the boat in and see if it leaks didn’t have the pump going on much last year so I’ll see what happens and hope I get a summer out of it
    looking for a used inner and outer transom assembly priced them out  new there $2000 separate if buy a full assembly its  $3000,and sell the new ring I just bought and installed in the boat ,still hoping to get the season out of it the way it is .Thats if I have no leaks and will do it all over again in the fall
  • raybo3raybo3 Administrator Posts: 5,568 admin
    I hate to say it but your problems could be much deeper than just replacing the transom Assembly. I had both of mine go. 1 last year and the other 4 years ago. Not only did the assembly break but caused quite a bit of fiber glass damage. I hope your sitting down for this but the total cost for EACH problem was over $15K. Transom had to be ground down and reglassed. Lots of labor. I hope your is not as bad but if it were me I would definitely get it checked out by a marine mechanic and have the transom looked at to be sure everything is OK............Good luck and keep us posted.
    Rain again today I have a inspection mirror and going to see if I can get a look at it .since it all was replaced back there I think I’ll fill the bilge to see if any water leaks out
    Tried to take a look at the inner transom with a inspection mirror and you really can’t see I ordered one of those scope cameras will be here tomorrow planning to put in on Monday and hoping I don’t have to take it all apart till the fall here is the before and after I even spent the $13.00 for the decals even the trim gauge is working haven’t had on of those for a long time
  • aero3113aero3113 Member Posts: 9,538 ✭✭✭✭✭
    Nice work, good luck!!
  • halifax212halifax212 Member Posts: 558 ✭✭✭
    Looks solid. Good work!
    Wow that looks some much cleaner. Good luck with the tramsom.
    Nice! Looks like two different boats! Good Luck
  • Dream_InnDream_Inn Member, Moderator Posts: 7,800 mod
    That looks really great!
    Ok put in today bilge is dry went for a hour ride tiny drips where the trim wires come in no big deal .the trim sender worked for about 1/2 hour then quit have to take a look at it maybe it wasn’t meant to be
    So on my way to work stopped by the boat turned on the bilge and no water at all took a look and a little water on the bottom so now I don't know if I should rip it all apart for the inner transom I keep the boat on a small lake so its not like the boat sees any 4or 5 ft seas no pounding or banging ,I think Ill play it by ear and see how the season ends ..I know the saying if its not broke don't fix it ....It just worries me its there
    If the drip is definitely coming from the sender wires I think there is a bung that you can tighten that might seal it back up. You can always temporally seal that area with some 4200.
    its just a tiny drip might seal itself up in a day or 2
