Recommendations on new AC unit
I have a 2004 342, AC compressor is shot. I searched but only found one article referencing a replacement AC unit. Can anyone recommend a replacement unit?
    www.defender.com/defender1st.jsp?trk_msg=C0T2C6BM5E6K946LP8S3GDOP5C&trk_contact=NIJ009AP55E6163AH3CQTOQQGS&trk_sid=O3LGK91KVM97T738O3DOT1B56S&utm_source=Listrak&utm_medium=Email&utm_term=https%3a%2f%2fwww.defender.com%2fdefender1st.jsp&utm_campaign=Defender+1st+-+Deal+Of+The+Week!
    It's a different brand but just seen this
    Get an A/C tech and just get a new compressor..........
    342guy342guy Member Posts: 5
    Reneechris14 do you think that unit would work? I know it will fit and it's 115 volts so it looks right
    I believe the one you have is a domestic so you will have to change the controller. This deal is just for this week. It is a blemishes unit???
    Dometic is the brand. 16,000 btu rev cycle
    I replaced mine 2 years ago. SO much more quiet. Humidity control. Variable speed fan.
    Www.marineair.com
    Kaptain_KenKaptain_Ken Member Posts: 75 ✭✭
    My 270 didn't come with A/C.  Previous owner installed a Dometic Turbo unit. It's amazing.  He said it's a 10,000BTU and I saw the receipt for the work, but I suspect it's really a 6,000 or 8,000 since I think 10,000 would be too much for the boat.  But I can vouch for these units.  Quiet and very power efficient.  I can even run it and my battery charger and other items on my Honda EU2000 when I'm on the hook.  They even make a cover for the compressor to reduce noise further, but I haven't found it to be necessary.  I'm going to verify the capacity when I get to the maintenance for it before I launch.
