Poor performance for 2013 Rinker 260
MIKES342
Member Posts: 182 ✭✭✭
Just curious to see if anyone is haveing problems with a 260 A/C, Generator Radar ARch, planing with 3 to 4 adults, full of fuel. I have to get people to move forward or it won't plane easily. WOT around 5000 RPMs is 39mph has anti foulding paint and the bottom is clean. over 4000 RPM's the bow starts to jump up and down until I use down trim tabs about 3 lights on the tab indicator.
When tryin to plane the tabs are half down and the engine all the way in. I have the mercruiser 377 with 320 hp that has catalyst. I have changed the props from 22.5 pitchs to 20.0 pitch that helped.
I have contacted my dealer to see what can be done to improve performance I have 19 hours on the engine.
Does anyone have a 260 with radar arch,6.2 bravo 3, genny and A/C. Just wondered what kind of performance you are getting? What pitch on the props and what is the gear ratio. What is WOT in RPMs. How long does it take to plane with 4 on board a full of fuel. Your responses would be appreciated as I still haven't heard from Rinker or my Dealer yet.
I guess I will have to chnge my sign from MIkes 342 to something different. I miss my 342 but don't miss the 2 hour trip to Lake Erie vs my 10 minute trip locally
Mikes????
I have a 2011 Rinker 260 EC, with AC, full water tank, full gas tank, 1/2 full waste tank, 1 crank battery, 1 large (31D) deep cycle battery, every compartment stocked full. I have a MAG 350 MPI, 5.7L, 300 hp onboard with 20P props on a bravo 3 drive.
My WOT is 5000 RPM. My top speed is around 40 mph, with trim tabs up and drive trimmed up.
I normally need to have trim tabs fully down to plane in a decent time. I can plane in around 7 or 8 seconds with tabs down and my family onboard, 2 adults, 2 kids. Without trim tabs down this probably changes to 15 seconds, assume a calm lake.
With more adults it slows down. My heaviest load ever was 6 adults and 6 kids, assume around 1500 lbs. A few waves out, call it 1 footers - took me around 40 seconds or more to plane - it was really tough!
I need to stay above 3600 rpm to stay on plane - this is around 22 - 24 mph. Fuel consumption is best at this range at around 2 mpg.
Mark,
I appreciate the information i think the generator is about 300 lbs. Wit just me and my wife I can plane with me and my wife in about 8 sec with full tabs down. Initially they had a 24p prop and it was miserable the 20 changed the perofrmance. Do you think it would make it easier to move people forward until you plane? Or may be I am just used to the twin 6.2 I had on my 342. I am cranking about 4900 to 5000 rpms and about 39 mph on flat lake. Of course I have bottom paint that will slow the boat down. Although there is no growth on it. Do you have to keep the tabs down a little at 5000 rpns to keep the bow from going up and down?
I really appreciate the information Thanks so very much
What a great solution this would be. I have been following this thread because I know how much Mike enjoyed his 342 which was quite trouble free as I understand it up on Lake Erie.
Tony
Salt Shaker 342
My salesman called today and said they were going to have Randy Rinker call me. Al, I haven't adjusted the trim stick as you suggested yet. The dealer is 100 miles away which adds the problem. If I were local to them it would be a lot easier to deal with. I will be taking it back to them for winterization
I really haven't taken the boat out of the water since I changed the props from a 24" pitch to the 20" pitch that they sent me. I have tried with full tabs down. Half tabs down all with the engine drive all the way down. The engine seems to be struggling and it almost sounds like it the engine changes speed right before it planes. I am currently WOT at 4900 rpms and 40 mph if my speedometer is correct. Although I don't want my top speed to be 35mph
I hate to think what this boat would have been like without the 6.2 liter engine. If I can get this taken care of I ill love my retirement boat. Right now I am missing the 342 but that will go away once this has been taken care of.
Tim,
I have attached the info for the trim pin location on the Bravos. The standard position for this pin on the Bravo 3 is in the aft position. It is recommended by Rinker to put this in the forward position as it will tuck the drive in further and help planing. Next if he runs the trim tabs full down not halfway before taking off and raising them after on plane, this will also help. The placement of weight in the bow will also help. You could put 150 lbs. in the bow storage and this would improve planning and help with the porposing. You could also space the trim tabs at the actuator to give the trim tabs a little down even when trimmed up all the way. We have spacers for this. Overall all manufacturers cruisers of the size 24 to 26 feet, because of the short length and tall height do not plane as well as the larger single engine cruisers.
Randy Rinker
Warranty / Customer Service
MTs idea has merit. They actually make extra tough custom sized flexible water containers with fittings that will unroll to fit in awkward sized voids for carrying extra drinking water capacity in cruising boats and sailboats. You could use it as water ballast that doubles as drinking water to add/replace the water tank weight normally kept in the stern where it kills performance. It'd beat carrying any more dead weight on your 260.
Be careful about getting the bow too heavy. It could cause handling complications in certain sea conditions. Good luck finding the right combination. Mike
Today I pulled the 260 actually the admiral drove it on the trailer. She really does a great job I handle the trailer she handles the boat.
I decided to change the oil and used a jabsco pump that you screw on the dip stick. I worked very well for my purpose. I then tried toget the oil filter off. It was impossible I used a normal filter wrench and crushed the filter. I called a local marina that I have done business with many times and they all know me. I asked them if they had time to get the darn thing off. They said bring it in. A young guy about 28 who was very strong couldn't budge it and the filter continued to collapse. Then he went to the shop and brought out a filter wrench that actually penitrates the filter for a better grip. He muscled it off finally. So we poured the new oil in the engine. I asked how much I woed them and the service manager said just give something to the man who took it off. I gave him a 20 and went inside and told the owner how great his service department was. I have known him and bought several boats from him and he has sold a couple for me as well.
Then I returned home and checked the Trim Pin that everyone has asked me to check. The biggest part of the plastic was facing the stern of the boat making it push the outdrive with more in trim. So that will not help the performance. I will try to add some weight to the bow next.
Oh yes I washed and waxed the entire boat also. I am 66 years young and it relly wore me out.
Hopefully adding the bow weight will help.
Another trick to easier removal of an oil filter is to take some engine oil on your finger and run it around the rubber gasket, then as BD suggests just tighten it until it's snug. To get them off when badly stuck I have used a long screwdriver, driven it right through the filter and twisted it off. That has always removed a too tight filter. It's not recommended procedure but a good Hail Mary. MT
I've seen, several times, that happen- most recently, a friend lost a brand new engine in a jeep because of it- he swung into one of those quick lube places because he was busy, and they 'stacked' gaskets.. he didn't make it 3 miles down the road before he lost all oil pressure (due to no oil), and locked the engine up tight as a drum..
for those of you guys with remote filters, it's easy to see whether it stuck or not- for you fellers without, it may be something you want to pay close attention to when you're removing the things..
