Electric and electric bielge pumps
rasbury
Member Posts: 8,972 ✭✭✭✭✭
So my recent near death experience (well not really) with water in the bielge for sure has me looking over my pump. So as another member as suggested, I for sure should have more than- which I do. I have one by the motor and the one under the mid ship berth where the thru hulls for the a/c and the head and the shower sump are.
So to test my pumps, there is a little part of the float that sticks out, assume if you raise that the pump should always come on under any circumstance correct?
I do not have any type of manual pump on board. I'm looking on line and see some but the hose is like two feet long- so what do we get for a boat that need 4 or 5' of hose?
The other way is automatic, when the float lever is raised. It should have power at all times in case you're not at the boat when she takes on water.
As for the manual bilge pump, i would pump mine into a bucket then dump bucket over board in an emergency situation. Sailboaters keep them because off shore rogue waves happen but the cockpit in a sailboat isnt as deep as your bilge. Thus they dont need a hose as long. Still an item i feel better to have and not need than need and not have being that its the size of a bike tire pump. If your battrries go your bilge goes.
I only boat miles off shore for a week a year and dont even do it in my boats but my boats are generally better prepared with safety and back up safety gear than the boats i rent.
Keeping water out of a boat is an item worth over thinking 😉
There are many sea stories about the physical exhaustion that comes from bailing water with a bucket. Yes, you're only moving the water a few vertical feet in a small express cruiser. But think about lifting a full bucket every 15 seconds for 2-3 hours while you wait for a rescue. With a tube-style manual pump, there's no wasted motion.
This one will move 13 gallons per minute, which would keep up with a pretty good-sized hole in your hull (like a generator intake).
https://www.westmarine.com/buy/west-marine--manual-bilge-pumps--P011_330_003_501?recordNum=1
Whale BP9005 Gusher Urchin Manual Bilge Pump - On-Deck Fixed Handle, up to 14.5 GPM Flow Rate, 1-Inch or 1 ½-Inch Hose Connection https://www.amazon.com/dp/B00144AQDC/ref=cm_sw_r_cp_api_i_Cx9gEbD6SHVKV
Besides, it'll never happen to us ... we carry safety equipment mostly so we can help that other boater who wasn't as well-prepared. Right?
My arms are long enough that I can operate it by laying on my stomach on the cockpit sole. I often wonder though what I would do if I lost battery power and couldn't open the hatch....
Say the boat springs a leak on a Sunday after you go home. Your bilge pump failed two weeks ago, but you didn't know, so the boat starts filling with water. When your dock neighbor calls you in a panic, you'll be glad to have that manual pump.
My paranoid brain can invent a hundred scenarios like that.
Yeah Ras, you're not the only paranoid one!
