I have a 2009 rinker 276 captiva bow rider. There is a fat green wire that hangs down by the bilge
trash1trash1 Member Posts: 3
Pump. It is not hooked to anything. It has a circle brass fitting on it. It just hangs there, I think it is a ground.help.
Best Answers
    Pic would help a ton, also what engine?
    2013 276 Cuddy ~ 350 MAG / B3
  • trash1trash1 Member Posts: 3
    edited August 2013
    Almost definately a bond wire for the through hull. No pics with me while I sit in a tragically boring meeting. Maybe this evening Il dig one up.
    Post edited by TikiHut2 on
    I have traced the wire down and it goes to a ground block at the back of the boat. This wire may not have a purpos, but it seems like it should connect to the motor. Any thoughts?
  • MarkBMarkB Member Posts: 4,002 ✭✭✭✭✭
    I think I have a green ground wire attached to my fuel tank.
  • IcebreakerIcebreaker Member Posts: 6 ✭✭
    edited August 2013
    FYI, I have discovered a ton of unconnected wires in my boat, including the mentioned green wire. I suspect most Rinkers comes pre wired for options you might not have. The one in the bilge is probably a ground strap for the genset. Mine was ordered without a bow windlass, when I started to install my new Lewmar winch I found that the wires where already installed, thanks Rinker :)
