I have a 2009 rinker 276 captiva bow rider. There is a fat green wire that hangs down by the bilge
trash1
Member Posts: 3 ✭
Pump. It is not hooked to anything. It has a circle brass fitting on it. It just hangs there, I think it is a ground.help.
Best Answers
212rowboat Member Posts: 2,591 ✭✭✭✭✭Multi meter on continuity is your friend, friend.. :-) if its a ground, it will be common with other grounds.. if its hot, it will be common with other hots.. if there is a fuse involved, and its blown, you'll not be able to check this until you replace that fuse.
Lifes Good Member Posts: 465 ✭✭✭
