Muriatic acid on hull
Willhound
Member Posts: 4,241 ✭✭✭✭✭
Season is now officially done. Boat pulled and blocked yesterday. As you can see there is a pretty bad scum line. I spent the afternoon with some hot water and a bottle of Starbrite hull cleaner and it took most of the tea stain off and some of the growth line, but not all of it. I'm hesitant to use Muriatic acid, but everyone at the marina tells me it's the only thing that will take that off.
Was going to put some in a spray bottle, apply, let sit a half a minute, give it a scrub and rinse it off. There's no running water where the boat is blocked, I have to bring it in pails and use a garden sprayer.
Am I headed for disaster? Should I just live with the little bit of stain that's left?
Sorry, never thought to take an "after" pic, it does look much better, but still a grey stain from front to back. The tea stain under the swim platform came off beautifully with the Starbrite though.
I used a 50/50 mix of muriatic acid and water for many years with my last boat. Pour water in first, then acid. Wear a mask and gloves. You may want to use a brush just to get the spray rubbed on evenly. Leave set for a minute or so, then spray off.
I could also use FSR (Fiberglass Stain Remover). It works well too, but takes a bit more time to apply. The Mary Kate On/Off also works, and I believe has muriatic acid. To me, if you are going to use it, just buy the muriatic acid.
muriatic acid will absolutely work, but it is not kind to trailers or tarmac. put Vaseline on any through hull metals, too, to protect them before applying acid. wrap your outdrive in a plastic lawn and leaf bag... anything metal or organic won't like it too much, but both citric acid and muriatic do fantastic jobs.
i'd want to have water present, though, to rinse thoroughly...
I can get this stuff: https://www.homehardware.ca/en/900ml-toilet-bowl-cleaner/p/4521244
Similar to the Works?
These pics in order are the hull fresh out of the water, after a pressure wash, after using Starbrite hull cleaner and then the stuff that actually worked. Only minor burns on my right cheek.
I could get indoor storage here...for about $2000 for the winter between transport and rent...
Star Brite Rust Stain Remover - Easily Clean Corrosion Stains Off Fiberglass, Vinyl, Metal & Painted Surfaces
