so, my fruits of the days work...
rasbury
Member Posts: 8,912 ✭✭✭✭✭
I really try to be positive. I'm sitting in my boat in the front yard. It has cooled of to a sunny 75 degrees...brrrr. I have a strong cocktail in my hand and I'm done for the day.
So, yesterday I got my new exhaust elbows installed...just about had a disaster by not installing the gaskets the way some well intended person said to. Thank goodness one of them I had not removed which sent me investigating and was resolved. Installed my new reservoir for the out drive (don't ask please), the wires were to short so had to improvise that one. The only thing not resolved on the motor, the two fittings on the exhaust elbow for the water hoses are just not coming out so I will order some new ones, no big deal.
Next on my list was to install the steering which was no big deal, still have to tidy that up a bit. I bag stuff up as it comes apart, I had one of the bend tab things in a bag with a nut and two washers...no clue where they go. I'm going to post some pics of a couple of wires I'm not sure where they go later. A couple I'm sure go to the starter, one from the mercathode block on the transom must be a ground that goes to the coupler housing. A positive and ground to the trim pump...
So,,,,,not to bad eh?
Now the bad news.
My friggin trailer. So, my son in law gave four take off tires and wheels that came from is 300 grand fishing boat that was cryin for some aluminum wheels. I put them on. On the way to the ramp for one of my recent dunk tests for leaking, one of them came apart. The brake seemed to be locked so I pulled it off and put my spare on. When I picked up the boat today, when I got next to buildings going down the road, I could hear just an awful noise- thought I had another flat or tire comin apart. Pulled down a street, found it was a dead end and after looking things over had to back out on a busy highway by myself, that was very exciting! So, nearing the end of the day, figured I'd jack up the wheels to see if I had brake issues...all the bearings were recently replaced. I get to the third wheel, when it came off the ground it had some wiggle to it...my heart sank as I started looking at the lugs on the wheel. One of the studs was sheared off. A few of the others studs are spinning on the hub. One or two looked intact. So, I guess when I put that wheel on when I tightened it up, it must not have been up against the hub or something? So, to save the cost of a hub, once I cut these lugs off, can I tack some new studs in the hub? I know if I have any future issues I will have to replace.
I was trying to schedule the motor to be put in this week...I'm really trying to be positive...
Don't use cheap Chinese made studs. Get good american made replacements. I cant recall and you may want to Google it, but akin to grade 5 or 8 bolts, the ticks on face of splined end mean something... Iirc you want the one with three half ticks on it, not the ones with dots or with 5 ticks...
You DO want FIVE tics on face. I was wrong above .
Good thinking so early in the morning!
We're all counting on you Ras! We gotta see some great pictures this winter of you boating! (Cause you won't see any from up North)
Dave
Moon Township, PA - boating in the Ohio River
I've seen people turn some masterful wheel hub adapters using ,high grade aluminum as well as straight stainless, and even billet steel as well, and then plop those studs in- everyone blames the adapter and harmonics for the failure, and it's not- it's the stud itself. This is why i was adamant for using "American Made" steel for that purpose. There is NO comparison for American Steel for this (and many more ) applications.
As far as the cause- if those ARE American Steel lugs, the only three causes that are associated with that type of failure is torque on the lug itself (I think it calls for 175# in feet), the wheel's hub.... which leads me to ask: are these wheels spoke style or the ones with holes in them? Both are guilty of this, but the spoked variety seems to be more prevalent and guilty of this- the basic concept is they push in and out, flexing, and 'wafering' the steel itself when it happens, which allows for even more flex. When they start flexing, it's time for a new wheel. Cast (or spun) aluminum doesn't do this. I've never met a steel wheel that didn't, over time and being assisted by salt- some attribute it to heat generated and then dunking in water, but i dunno.... When road noise is introduced and the vibrations turn into harmonics, the steel around the lugs and from the hub to the beginning of the spoke vibrate, and the lug nuts loosen. The third cause is the lug nuts themselves, and is generally folks using hub centric lugs on lug centric wheels, or vice versa.. (one is flat, one has acorn base- one holds by hanging the wheel off the hub which has a tight tolerance to the wheels inset, and the other relies on clamping power and the 'acorn' lug nut centering the lug and aligning the wheel- both are sufficient, it's just you can't mix them unless you're using both wheel AND hub centric setups, which isn't that common)... Also, and still discussing lug nuts, ALL of them should have a slight taper (which is where the Chinese goof in addition to using lessor steel) which allows the threads to really latch on and stretch the lug threads (at proper torque) and become almost as efficient as solid steel studs holding that wheel on...
those bosses aren't splined. they are tapered. are the studs used splined or tapered? newer hubs are splined almost exclusively, but in all honesty the studs usually last the life of the hub. I've literally seen cars with drum rear brakes from the forties, all restored in their former glory and the hubs and studs remain OE...
i've also seen cars from the fifties with working brake light switches, turn signals, and windshield wiper switches still functional after all this time too- as if we forgot how to make them or something, and chose to use plastic doo-hickies instead nowadays in our 'planned obsolescence' or 'engineered to fail' mentality of today with intent to double whammy consumers- which would be my primary complaint to legislators to remedy if there weren't obviously 1000's of other more pressing matters to attend (and here is where i digress, as it really doesn't matter here and really tweaks me anyway)....
so anyway....
as i see it you have two choices to make this right, and right is the only choice to keep you and your family safe, as well as those driving around you while you tow:
get new hubs and wheels. or. get new wheels and hubs.
the mention of stud/hubs above, being good after 'all these years', is to introduce the idea that they don't have to be 'brand new' (as in a pick and pull project), but they should never have been separated.
