Which seawater pump would you recommend?
davidbrooks
Member Posts: 1,353 ✭✭✭✭
So It has been my standard operating procedure lately to fix one thing (boat, house, work) and a new thing breaks right away. So yesterday i flushed out my starboard engine and seemed to have resolved the overheating issue. On a test drive into Annapolis it was all great. Coming home almost to the dock when the port engine warning horn goes off and temps are WAY up. I shut it off instantly and temps then pegged at the top of the gauge. Lifted the hatch, looked in and the belt was laying in the bottom of the engine compartment and the pulley fro the water pump was sticking out about an 1in from where it should be. So i limped in on one engine, came home and started looking for parts. I haven't pulled the pump off yet but from the looks of it. The pump looks rebuild able and i am betting the lock washer failed. I have seen replacements that range from $260-$460.
Lowest Price option found EMP branded on on Amazon $260 https://www.amazon.com/gp/product/B074CKGN7T/ref=od_aui_detailpages00?ie=UTF8&psc=1
Highest price option GLM brand on Amazon $454 Brass
https://www.amazon.com/MERCRUISER-BRAVO-ASSEMBLY-GLM-Number/dp/B004AQVPRW
I have found the brass ones for as low as $350 but i dont know anything about them. They seem like a better choice. Cant tell if they bolt up the same, come with a pulley or i use my existing one,need to buy one...
Or am i missing a better option? Thanks All.
PS.If someone is testing my patience by continually breaking things please stop and i promise to go to church on Sundays instead of going out on the water.
Try these guys.
Must take note of the shaft to make sure when reassembled it the same length.
I used a harmonic balancer puller (which Hardin recomments) and a 3-arm pulley puller. Maybe I just needed the puller that @reneechris14 posted.
My port pump lasted 3 years/180 hours before the main seal leaked and destroyed the bearings. I rebuilt it by replacing all seals and bearings with their kit.
It failed again this month, after 2 years/143 hours. When I reinstalled it, I noticed that the stbd pump is leaking (5 yrs/323 hours).
So, by my (very limited) records, the MTBF is around 200 hours.
