gaskets for riser and manifold...
rasbury
Member Posts: 8,835 ✭✭✭✭✭
I'm do confused....I have the 350 MPI motor, 2006...so confused between dry joint, wet joint, cold riser...etc.....so I'm putting my new exhaust elbows on and someone is telling me the blocked gasket goes on the bottom at the manifold and the full flow goes between the riser and the elbow-one of my manifold gaskets is still on there and it for sure is the full flow gasket...and would look like coolant would go through the riser....also looking at the parts manual and while confusing as well, seems like it is saying for closed cooling with riser the full flow is on the bottom and the restricted goes on the top....I'm going with the full flow on the bottom and restricted at the top so if someone might confirm before I fire this sucker up, I'd appreciate it....how about it @Alswagg or are you snowmobiling yet??
Make CERTAIN youre using correct gaskets.. Its easy to goof as there are so many to choose from. Match numbers if necessary. The manifold is CLOSED cooled, the riser is RAW. You have dry joint manifolds, hence the two passages on either side of the square exhaust gas passage... Wet joints have passages built in aside the big square one. The coolant FROM THE TOP of the MANIFOLD routes back to exchange as that is hottest it will be... The passage in the riser which in dry joints has a little cast pipe linking them via 90* elbow (or sometimes cast into mold) is plumbed to the OUT of the heat exchange. That heated water from the exchange goes bye bye through the riser.
The difference between half kit and full coolant kit is if the manifold is raw or fresh water cooled. In a half kit the exchange routes to the manifold NOT the riser... In a full kit the manifold and riser use different cooling systems... One raw (risers) one fresh (manifolds)... This is where gaskets are super important. The barrier between them is the gasket alone, or if youre smart you pony up for a stainless plate and either gasket both sides or use black rtv and make youre own sealing surface.
If youre a full kit, I HIGHLY recommended that stainless plate.
Does heat exchange OUT plumb to riser or manifold? That simple... If it plumbs to manifold you have half kit... If it plumbs to riser only you have full kit.
Full kits protect manifolds and make sacrifice of risers alone (which are cheap and easy to replace) where half kits sacrifice both risers and manifolds, but protect block, heads, and water pump just like full kits do.
Sorry lol
I will pull the main hose off the circulation pump and hopefully get most of the water out of the block and move forward. I have some wiring to tidy up and then I'm done at least with this saga....
