Mechanic Saga continues, MAYBE
If you remember I posted the mechanic at our marina pulled both drives off and put them back on. Anyway, the first time taking the 342 out and both engines overheated immediately (225 degrees. Shut down and was towed in). No water flow at all (check the "cans" and antifreeze still in strainers). I have a couple questions to our members, 1. could the mechanic make an error when replacing the Bravo III drives back on to disturb the water intake? 2. Has anyone heard of both water pump impellers failing at the same time (impellers are 2 season and one season old)?
At this point, best to just change out impellers, make sure you collect pieces, and run at idle up to temperature. All can easily be done in the water and take maybe a couple hours to do both engines. Hopefully there is no big deal. Other thing may be that your pumps just didn't prime (maybe due to wearing out inside pumps - need to check this when taking apart).
That being said, after winter, I always pull the blue plugs the first time I put the boat in and wait until I see water get to the pump. Why? because after sitting all winter, there's a chance that there may be nothing in the hoses. Priming takes care of that.
At this point, why not just take two hours and change out your impellers and be done? I've already done 6 engines this spring, not a huge deal. Out of the 6 (all 2 yr old impellers), half were definitely ready to crack on first start up. Bill, if you were a bit closer, I'd have already been there and changed yours out for ya!
At a minimum, after the boat is put in the water, pull the blue plugs just to make sure water gets to the impeller before you start it (pull the upper blue plug on pump - lower one won't have water because it is after the impeller).
With a long trip last year and one planned this I decided it was time anyway, both were (are) in very good condition so good for emergency spare. Yes, some vanes were not springing back out as they should and flow would have been down (with VVMM I'll know that now!).
I think it also depends on what you are sucking through the pumps - where we are is pretty greasy mud so if anything gets sucked in it's likely to be somewhat lubricating versus sucking in sand and gouging things.
The pump can easily be pulled in the water. Just raise the hose that comes from the outdrive (after removing from pump) until it's above the water line. If there is no water at pump at all when it is sitting in water (assuming you pulled correct blue plug - top one on pump - or both of them), then you have a different issue all together. No water coming in top hose to the pump with boat in water means you have blockage coming in from outdrive.
Onislandtime you mentioned that you have through hull valves. If so you should have plenty of water at the pumps even if the drives both have blockage. Did you pull the upper plug as Dream mentioned? Not lower
I had exactly that same problem when they changed my impeller. We were getting low cooling water pressure (raw water) and when we unscrewed the blue wingnuts, air lock was released and we went back to normal, flow and temp were fine.
