How to open the engine hatch with the batteries disconnected
LaRea
Member, Moderator Posts: 7,920 mod
On boats with an electric engine hatch, there are three ways to open the hatch when the batteries are disconnected.
Few people know about this one: (thanks @Liberty44140 )
Most people know these two:
1) Connect the boat to shore power, and turn on the battery charger. At the cockpit breaker panel, turn all battery switches to the ON position, and turn on the "Helm Power" switch.
2) Connect a 12-volt battery to the jumper posts on the DC breaker panel located in the cockpit. On some Rinker boats, you can also reverse the polarity to close the hatch, but that will not work on all models.
3) Remove the base for the cockpit table, reach in with your arm, and remove the release pin at the top of the actuator. Then you can manually open the hatch (which can be quite heavy).
I'm watching this one closely....
For the past two seasons, when winterizing I always remove batteries. My 300 is one of those that connecting to the posts does NOT close the hatch by reversing.
My solution has been to tap 2 wires directly in to the power wires to the lift cylinder; then run them through scupper to swim platform, and connect directly to battery. Then the cylinder can be operated in both directions.
Problem is this procedure fries the relays on backside of battery switch panel. They aren't expensive ($8-$10 each), but a PITA every year to replace.
If I'm reading the original post correctly, with NO BATTERIES in boat, plugged into shore power, with battery charger on, and battery switches ON, and helm power ON, the hatch should operate?? That would be SWEET!
I also am interested in the 12v plug method @kordo mentions....This sounds much safer without frying any other electronics (battery charger). This presumably back-feeds everything to make the switch work? There must be a combination of battery switches and helm power breaker requiring ON position as well I'm guessing.
I still have the OEM charger and it operates fine so I don't want to risk.
Good topic, and I'm hoping to nail down a solution!
