A new MerCruiser rocker/oil problem, and a related question:
My port 496 Mag quit on me the Friday before Labor Day weekend last summer. The season was winding down so I used it as a floating condo for the last 6 weeks of the season to avoid paying another $1100 of in and out lift fees to have it repaired quickly enough to catch the last month of the season. The marina was supposed to fix it over the winter but they didn't get around to it until a month ago or so. I thought maybe the issue was related to the fuel rails and injectors not being repaired properly (see my other thread), but it turns out the rockers cracked due to poor quality design or construction. It took the shop a long time to determine the problem. I formally asked MerCruiser to send out a rep to determine the problem but they failed to send a rep. My service manager finally fixed the problem himself. When he was testing the engines, a rocker on the starboard engine failed. Both engines down, he had racing grade rockers made. The problem is that he only replaced 4 of the 32 rockers. He asked if I run the boat at WOT for long periods of time and I said only to get up on plane. Could the performance be related to the painted fuel rails/injectors issue? I'm now afraid to attempt to get up on plane for fear that another rocker will blow early in the season and be relegated to miss more boating season to get in a long service line again so soon. Engines should be able to handle getting up on plane without rockers breaking apart. Check out these photos:
Post edited by Jodijoe on
I would have pulled the others and looked for wear/heat affected zones. Is this a stock/OEM engine?
MERCRUISER SERVICE BULLETIN 2001-6 "Required 496 MAG **** / 8.1S
**** Push Rod Replacement"
2001-2002 MCM 496 MAG **** sterndrive engines (s/nos OM025976
through OM025985 & s/nos OM061091 through OM061773) and MIE
8.1S **** inboard engines (s/nos OM026663 through OM027049)
Warranty codes: MM72, MX16 & Uniform Failure Observation (UFO) 423
-40
fuel rail and rockets are completely different systems
Were the failed rocker arms on the exhaust valves only?
you might ping 212rowboat too. Super knowledgable engine guy on here.
Honestly, broken rockers are rare in Merc engines (really, all GM engines). As far as I know, it only happens under unusual circumstances.
Out of curiosity, did you purchase a professional engine survey before buying the boat?
if it was mine I would start it with valve covers off. To see oil flow.
i may have missed it, but what cylinders were these atop?
the very first thing is where they broke. they appear ripped right off the pedestal. they ain't supposed to move except over the ball cap... any up and down from improperly torqued rockers or from a stud pulling even slightly and you have forces changing from focused on the ball to on the stud- where no oil system can assist... it's often confused with deflection, but it's not. it's basically testing the meddle of a bolt/stud's sheer strength as opposed to it's torsion strength and for which it was designed...
imagine it being held snug- such as a wheel is held snug to the hub.. it can take all kinds of weight and abuse so long as it doesn't wiggle.. if it can wiggle? you've not only created a new friction point outside the design envelope, but each time the wheel shifts it gets a running start without resistance until it slams onto stud.... same principle here.. if that rocker was loose even a little bit it would soon be a lot as the stud further pulls from the head and/or stretches... it wouldn't do that without a head start....
if it were hydro lock the push rod would most likely have bowed first, or snapped. i'd be curious to see those. if the valve springs were floating *basically the springs compressing to the point they can't rebound quick enough to close completely there could have been some wiggle created- but what those pictures indicate isn't something that happened like that with the discoloring- it was done over time. besides, they'd have to been REALLY loaded for extended periods for that to be a concern.
i'm going to go with bad install (improperly torqued) rockers OR a stud pulling (but twice?) as a secondary. i'd like to see a pic of the pushrods under those two, though, as a bend could indicate a leakage in the cooling system under load and RPM that caught it just right.
do you allow the engines to reach full operating temperature before slamming WOT? thermal expansion and married surfaces tasking gaskets (especially cold water from a raw system) could cause a momentary leak on a soon-to-be-failing cooling system and cause the carnage... which will again be evidenced by bent push rods.
UPDATE: The split rockers were from Starboard #8 and Port #6, both exhaust side. My service manager installed 4 racing rockers and advised all the rockers be changed if this happened again. My boat was cleared on May 10. I ran it at around 1200 rpms because we had a boating event to attend this past weekend and I was afraid it would fail. Sure enough, yesterday, May 19, coming back from the event, I pushed it up to 1500 rpms near my marina, rpms were different from each engine. Port engine stalled and wouldn't restart. Had to pull in on one engine. Repair lasted one week. Same symptoms as Labor Day weekend last summer. Sounds like more rocker problems? Stern drives. Not sure which cooling system. Could this have been the result of screwing on the rockers too loosely? Would the rockers have been loosened or removed during the recall repair of the fuel rails and 16 injectors? I'm just trying to understand so I can keep my boating sanity.
THANK YOU SOO MUCH.
and
no internals stay put during fuel rail repair
So is it likely to be a manufacturing defect if the rockers were overtorqued when the engine was constructed?
It sounds like 212rowboat thinks the rockers were under torqued, loose, and the repetitive wiggling under pressure split them apart. What other repair would necessitate a mechanic loosening the rockers? The boat has <200 hours. Although, they do appear to be bluish or maybe heated.
