Need help with VVM hookup with twins
Spyderweb
Member Posts: 963 ✭✭✭
Finally got up to boat for launch. Checked out engines for VVM hookup for unit bought on sale this past winter. I understand I need 2 harnesses and 1 J Box. VVM plugs into J Box, 2 harnesses from J Box go to engines. I will then need to have the port engine have its CityID changed to PORT (CityID 12)
1st photo I believe is the port engine. From what I have learned here, I believe yellow cap is to be removed and 1 harness from J box plugs into that plug. From there, the wiring goes to another plug (purple tipped shown just to the right of the yellow terminated plug), then wires go elsewhere.
The 2nd photo is starboard engine, and different looking plug. Same yellow terminated plug, but it does not lead to another purple tipped plug, like in the port picture. Again, I would think the other harness from the J box plugs into the starboard yellow terminated plug.
Then I am supposed to do a "power disconnect" on one of the engines. l don't know what I am looking for to be able to do the "power disconnect".
Any ideas?
Paul
2008 330
Any ideas?
Paul
2008 330
https://rinkerboats.vanillacommunities.com/discussion/9690/mercury-vessel-view-mobile-on-sale/p2
Am I correct in that by removing those 2 yellow caps I expose plugs that the 2 harnesses would plug into?
The power disconnect on mine was 6 or so inches back down the harness on both per my photo and I disconnected the starboard one.
Now for the "power disconnect". Looking at my 1st photo, the yellow tipped plug attaches to a purple tipped plug whose wires then disappear into a harness. Is that the harness I would follow to find a "power disconnect plug" that needs to be unplugged?
Re the disconnect maybe yours is different, look at my photo again and the second shows a red, black and purple into a connector that is inline back from the SC connector, the same wires you can see in the SC connector and why you unplug one so that the VVMM is powered by one engine only. I’d call Merc and with your serial numbers they should be able to tell where a disconnect is, assuming there is one. Unless there is another harness or connector you need to put on to block or accommodate the potential 2 power sources.
Now, since both engines appear to have "terminator caps", does that mean I need to order a "plain cap" for the 4th slot in the J Box?
And am I correct that the 4 wire plug on the VVMM just remains capped, while the main plug goes into the J Box?
And, after disconnecting the "power disconnect", does one or both ends needs a cap?
Yes.
Yes.
Best to cap to keep dust out although I haven’t yet.
Go to your port engine and find where the blue data harness is plugged into the drop for data bus. A couple of inches from this plug will be another 3-wire plug. Unplug this connector from each other. This is key on power to data bus.
What you have is the key on power back feeding through this circuit so unplugging one will eliminate this back feed and each engine will now be able to be keyed off from its own key. However, get in the habit of always keying on the starboard engine first or even if you do not start the starboard engine and want to start the port only, you need key on power from starboard engine on to provide data bus ignition power. If you only key on for the port and you have this 3-pin connector unhooked on port engine, the vessel view will not come alive because there is no key on power being sent on the data bus.
Serial # tag missing from other engine
New problem. Just got call from marina. They can't reset port engine to "port". Computer won't work on Merc site. They recently lost their designation as Merc Dealer. No longer sell the Larson line and hence don't sell enough Merc motors and drives.
@Stodge Thanks for info. I passed it along to mechanic. Mechanic did search for power disconnect and doesn't see anything either. Thought perhaps it's buried in wiring loom but didn't want to take that apart on me. Is it likely buried in loom?
Start another thread re your "keying" issue?
@Spyderweb - let me see what I can find out for you.
VesselView as in a display etc at the helm perhaps works the same way - need to disconnect one engine.
