Small buffer
rasburyrasbury Member Posts: 8,972 ✭✭✭✭✭
I have a large electric buffer for doing the large surfaces but I would like to find a smaller one for tighter areas.   Are orbital polishers just a vibrate basically? I would like to get air powered but do not have a compressor...
    Orbital means it spins around but rather than in perfect circles it travels in an orbit, or non-concentric. Less chance of leaving a burn mark from settling in one spot too long. I think you'd be wasting money on an air model. Electric does a great job and can run it anywhere there's power or a generator. Not sure what you classify as big but I love my Porter Cable orbital.
  • rasburyrasbury Member Posts: 8,972 ✭✭✭✭✭
    That looks like it would work great and will get one...but I'm also thinking about something more one handed also rather than my really big buffer...I see random orbital...what exactly does that mean? I don't have heavy heavy oxidation but do need something that will have
     Some action! I wish I had a compressor...
  • aero3113aero3113 Member Posts: 9,878 ✭✭✭✭✭
    If you went air, your compressor would be constantly running and would need a large tank to keep up with it. I recommend electric also.
    Random orbital means that as it spins it constantly changes the direction of the orbit (the non circular pattern) so that a new area is constantly being buffed to avoid burn marks and give an even finish. It does this by using two offset gears that spin the head. Although there are hundreds of variations in the pattern it isn't truly "random" since there is a limitation on the different patterns but there are so many it would almost be impossible to track them.
  • IanIan Member Posts: 3,064 ✭✭✭✭✭
    edited August 2019
    I have a number of the Ryobi One+ tools and so the 6” and 10” units are part of my set. The 6” is a good one handed unit I use for first step with the 3M and the bigger for buff up and shine.
    i got these to make use of the battery system I have and they work well for me.
    Thanks..the thought of fighting with that big friggin buffer...and battery?
    Actually the small one is pretty nimble to work with, even one hand, balanced pretty well. The larger is 2 handed but also easy to use and balanced well.
    yea, that is what I'm looking for...just have to see if the wallet can handle it!
    I use a 3” random orbital from griot’s garage for the small areas
    https://www.griotsgarage.com/product/3+inch+random+orbital.do?sortby=ourPicks&from=Search
    @rasbury a good investment and decent pricing if you want to build up a few tools with the common battery system. I also have a fan, pump/inflater, lights, vacuum, saws, drill etc and happy with the tools.
    @Spyderweb looking this over finally and it has a set of three recommended pads to buy with...that the ticket?
    So, I pulled the trigger on this...145 bucks with Amazon free shipping...comes with a case and 8 pads...same brand. Dam Amazon.
    I thought this was about food
    @rasbury So which did you get?
    @Spyderweb i got the one you suggested just went to Amazon and got a whole "kit" from the same company- can't wait to get it and get to work. FL boating is just getting started!
    ok, I changed the topic from Buffee to Buffer.  It was driving me crazy! :)
    Thanks lol...handy keeps looking for a picnic basket...
    Good for you @rasbury.  I’ve found it’s a good complement to my Makita rotary and porter cable dual action.  Makes it easier to do so many of those little areas that the bigger tools just aren’t made for.  I even used it to polish my daughters headlights on her 2010 car the other day.
    So it came with like 3 different color pads..will have to read up. I've kind of winged it and experimented with different pads...never found a step by step with what type pads to use...
    Orange is called a "correcting pad".  That's the one I've always used.  It's coarser and more effective if some oxidation.  Black is called "finishing pad".  It's a softer pad, not as aggressive, perhaps better for a product like 3m Finesse II.  Red is called "waxing pad".  The softest.  I've always used Collinite 885 paste wax, so not very conducive to machine applying.
    That's what I'm thinking...putting wax on at 10000 rpm sounds like a big mess!
  • GMSLITHOGMSLITHO Member Posts: 1,619 ✭✭✭✭
    I usually apply the wax by hand and remove with a  machine
    me too...
    This little polisher works really well...you have to get the hang of it...I wish it has a wool pad...the most aggressive foam pad is not aggressive enough but it does a pretty good job and light/small enough to handle.
    I wonder if using a more aggressive polish would help?
    probably...when I use the larger buffer with the 3M heavy oxidation one step, it really leaves a very nice finish....so a heavier grit would probably require a lot more to finish to s nice clear surface...
    edited October 2019
    Making progress but dang! I'm not going for show room...in the FL sun it is not going to last so not going for great, going for good and it is looking good. I got the swim platform looking better than it ever has and hopefully the sealer will keep it cleaner.
    The disappointment is the small buffer- the backing plate flew apart...so the description it an orbital buffer. Which means what, it goes around in a circle? And then there is a random orbital.. what's the difference? I still have around the helm do I need to get it replaced.
    "the backing plate flew apart" - Wow, how does that happen?  I know you haven't had it long.  I would contact Griot's garage and let them know.  Maybe send a picture.  you might get lucky and get sent a new plate.
    The tool is actually a "random orbital".  I checked mine, and the front of the box says "orbital" and the back says "random orbital".  So inconsistent labelling.  So random orbital is spinning around AND vibrating.  Not as aggressive as full orbital, but less likely to get yourself in trouble.
