Problem shifting bravo III into forward
Spyderweb
Member Posts: 947 ✭✭✭
Out on boat 3 days this past week. Several times port drive did not want to shift into forward. Played with throttle a bit and eventually it would “clunk” and go into gear. It was intermittent. Most of the time it shifted ok. Talked to service manager. Said most likely shift cable is stretched (likely 11 years old). Said sometimes they can adjust it to buy more time before needing to replace. He said he would have his guys look at it.
Got call today. I was out and wife took call. He said the techs could not duplicate it. Said next time I was up to boat I could take tech out with me and try and duplicate it.
Problem is intermittent. Does tech really have to produce problem to fix it? I thought there were specific measurements and specs in installing/adjusting shift cable. At some point cable could be too stretched to achieve those specs and it won’t shift until it’s replaced. So I expected a call saying they readjusted it OR it’s too worn, I need a new one.
Am am I missing something here?
I am storing it this winter at a new place (the one that finally re-programmed my port engine so VVM would work) and they have a very good reputation for working on Mercs. I'll just have to place my faith in them. But certainly with all your help, I'll have a better idea of what questions to ask.
Nope, just the cover.
Item #3
http://www.marineengine.com/parts/mercury_marine_parts/sn/0L794086/5441500LS/5398_100
BTW, you nailed it Al. Earlier up in this thread, last Fall you recommended shift cable replacement AND cone clutch replacement.
