Would you buy a 3D printed boat?
    edited November 2019
    You must be bored Stodge
    LOL I saw it on LinkedIn and had to share.
  • IanIan Member Posts: 2,778 ✭✭✭✭
    Great technology for prototyping but it needs a lot of refining to make an atractive vessel I'd buy. Some of the more advanced additive manufacturing processes with metals are providing higher quality results as used in aviation areas.
  • MarkBMarkB Member Posts: 3,962 ✭✭✭✭✭
    That is an excellent idea. I absolutely would buy a 3D printed boat, I think quality control will ultimately be better than with current manual method ... and cutting out a lot of labor, I suspect the price points would move DOWN.
  • LaReaLaRea Member, Moderator Posts: 7,535 mod
    It's just a matter of time.  Large-scale AM is a huge investment area these days.  I'm not sure when it will trickle down to rec boats.  It'll start with military and law enforcement.
    Not saying hand-laid boats will go away, but AM is coming to all types of manufacturing.
  • randy56randy56 Member Posts: 4,083 ✭✭✭✭✭
    That's awesome, wish they would have spent more time showing us the boat instead on advertising there company.
    For only $25M, you too could print your own 25-foot hull!
  • PickleRickPickleRick Member Posts: 3,884 ✭✭✭✭
    With the advancement of polymers how long before we have a literal plastic hull.  Build your own 28 to 30 ft trawler.  Use recycled plastic for your materials.  No one cares if a trawler cabin looks  boxy mine craft drawn.  Power her with two recycled isuzu 2.2 reefer engines that are decommissioned for EPA regulations paired to a couple cheap used outdrives.  The older volvo drives could be made counter rotation by flipping the f/r cable. I like inboards but rudder design can be an issue and backing inboards is always a gambel.
    With a polymer hull you could have a water ballast keel making her easily trailerable yet stable in the water.
    Dropping the ballast may even make a proper design semi displacement hull fairly fast on smooth waters.
    I guessed that it was a $25M facility, but I was wrong.  It was $40M.
    @shawnmjr.....there is already a printer for that - Xerox Color Industrial Pro.....makes great $100 bills.
