Joining the trailer crew. Question for 270 owners with trailers..
J3ff
Member Posts: 4,061 ✭✭✭✭✭
EDIT: Found the answers here https://rinkerboats.vanillacommunities.com/discussion/3088/fv270-tri-axle-trailer-set-up-and-dimensions#latest if anyone else ever needs measurments
As some of you recommend my next move is a trailer. Picking up a used one for 2500... It only really needs to move the boat 4 tenths of a mile to the storage yard (150 per month with boat on or off of trailer).
Would any one be willing to measure the distance the bunks are apart and the distance from the ground to the top of the bunk? Going to try and set it up tomorrow.
Comments on price?
It's a 10,400 lb weight trailer, loaded down my boat was 8800 lbs on a lift... So hoping that with it unloaded we are good to go. Any other thoughts? Here's a picture... Brakes are in rough shape, but again, it will not be moving it more than half a mile each time.
Comments on price?
Post edited by J3ff on
How does 150 a month for storage sound?
Good luck with your repairs and keep us updated!
First major concern is brakes. Don't matter how far your going, if you don't have sold brakes your really asking for trouble. The calipers look rusted and even after a short trip the rust would be cleaned off. I'd start up front. If the is no fluid and/or the resivoir is crudded up the hydraulic system should be rrplaced- which is not as bad as it sounds. New resivoir , back up lock out and brakes lines is 3 to 400 bucks . The calipers are pretty simple and a rebuild kit is also pretty cheap- brake pads also pretty cheap if you need them. Then you can stop. I also pull with an f150 but the truck is not going to stop the boat- don't matter if it's a 350. These trucks weigh 5 to 6 and your boat 9 or 10. This is easy straight forward work to do but messey.
Tires are no fun to change on the road. Can't go by how they look. There is an age stamp on the tires- 5 years and they go. Replace with e rated tires. Then you will be all set to go where ever you want, or your 1/2 mile trip safely.
Your f150 might do just fine for your short haul.
I just never put brakes on my sailboat trailer as it got used twice a year, they would rust in place between uses if i was anywhere near salt water, im not near salt water but i feel i have enough stopping power with the 8000 lbs suv that i didn't want to deal with the hassle, drums dont like sitting even in fresh water. Not long after i got the sailboat i traded my fj40 for the excursion.
It took me a month or two after purchase but brake system rebuid was a must for my rinker. I tow 1.5 hrs round trip mostly freeway each weekend.
