Pump out adapter
Stever00
Member Posts: 145 ✭
Does anyone make a screw in pump out adapter for the pump out opening in back of a 240 Rinker. I bought macerator pump and haven't figured out how to plumb it. Every thing is made for RV's. Would something like this work?
YouTube has some macerator diy pump outs where you just plug it in, put the hose in your waste hole and then suck out your tank.
Ive thought of this as i dont have a holding tank but do have plumbing for attaching a pump out toilet. Getting in and out of the boat to manually dump a porta potty in the dump out pit sucks. I love my family but i hate their poop.
Wet a rag and wrap it around the small suction end of the macerator then press into the opening for the pump out. Make sure your discharge hose is where you want it because it's going to suck @10 gallons a min.
Make sure you are using the rv toilet paper so the clumps of toilet paper dont clogg the pick ups in the holding tank.
Clean off macerator by rinsing with clean water and then store.
With no macerator pump out in the boat the water poop police will never hassle you.
As for pump out, it's pretty simple. Most gas dock/pump out stations will have the adapters. Usually the waste outlet is a 1.5 inch threaded opening. Their pump will easily empty a waste tank.
Doing a home grown pump out can work the same way. They sell portable pump out tanks with pumps. Otherwise you could get a similar pump and plumb it to your home's septic system. It would work the same way, connect to the waste outlet and pump away.
I still wouldn't permanently mount that in the boat. I'd push the sucking end into the waste pick up fitting and suck it out each time i used it. How are you going to get a hose to attach to the hull fitting and fed into your waste container?
If you do mount that in your boat you need that drain hose to attach tightly or you're going to have one nasty squirt gun.
But you should know that if you are boating in fresh water and you are boarded for a safety check they look for Y valves. If you have one and it's not locked (pad lock, zip tie, etc.) it can mean a ticket.
If possible I'd look for a pull option. Than you avoid the plumbing in the boat.
I'm not cutting hole in bottom of boat or putting in Y Valve or what ever you ocean people do. If they can pump it out at a marina there should be a way to do it at home.
I'd personally either buy a shop vac + 5 gallon bucket ($75 all in) or a 110V macerator and some plumbing (to leave at home). Less work, less expense, less smell, and more time on the water.
No need to replum your boat. You can pump any boat, you can pump your boat at the camp ground/home or in the sewer uncle Eddie style. Just kidding about uncle Eddie sewer pump out.. A little post Xmas Christmas vacation humor.
https://www.dometic.com/en-us/us/products/hygiene-and-
sanitation/sanitation/accessories/dometic-tanksaver-_-25365
