sea valve access...
rasbury
Member Posts: 8,994 ✭✭✭✭✭
New proud owner of a 2005 270....I'm trying to get a handle on things before I put it in the water and have a few minor things to fix to be sea worthy......on my survey, it was found that the sea valve for the gen was stuck open. First, can these be serviced and 2nd, how the heck do you get to it? It was pointed out during the survey that it was underneath the boat, right beside the depth sounder pickup but I don't see any access to it. I would like to understand where all the sea vales are located and how to get to them. I have all the manuals as it was a one owner boat which will help with replacement parts and stuff but it tells you basically nothing about the operation of this boat. I know most is common sense. For example, and keep in mind I'm just looking at this big beast sitting out front wondering what I got myself into, on either side of the boat there is a fitting that says "water"? I know it only has one holding tank for clean water and then a tank for the other.....is not one of these "water" fittings for pump out? I'm going to have a lot of questions I'm sure....also, looking on the power panel, and I have a gen., what the heck is the reverse polarity mean? It has shore power as well as the gen. On the plus side, I did figure out how to turn on the radio....also, I hit I was playing on the dash and hit the bilge switch....quite a bit of water pumped out. Aren't the bilge pumps on a float switch and should it not have automatically pumped it out? Must have been all the rain on the way down but was surprised.....do both pumps work off the same switch? Really love the boat and can't wait to be ready to hit the water and as soon as I get her all cleaned up I will post the pics! Also looking at a lot of other fittings coming out the sides, some above and some below the water line and don't have a clue yet what they are but soon will!
rasbury,
I have a 2005 342 but can help a bit. As a matter of fact, I just had the generator Seacock replaced because it would not close all the way. It is in your engine compartment next to your generator. One of the hoses off your generator will terminate in the floor of the boat. A foot or two before it reaches the floor, you will see a value/handle. When the handle is in line with the hose, it is open and lake water can be pulled in to cool your generator. When the handle is at 90 degrees to your hose, it is closed. Not sure how you replace it since I paid the marina to do mine but it only costs about $150 labor and all. Your other Seacocks will be for the toilet which uses lake water and one for the A/C unit if you have A/C. Some of the other fittings on your hull are the drains for the sinks and shower and the output for your bilge pumps. Yes, the bilge pumps are automatic and work off a float. You probably had enough water in your bilge for the pump to pull it out but just not enough to activate the float. Or the float might be stuck. I'd check it. Both pumps work off the same switch. As far as reverse polarity, when you connect your shore power cord, sometimes the poles get reversed and you just need to turn off the power at the dock and reattach the cord to the boat until you get the green light......someone else knows more about this then me I'm sure.
Your waste tank opening is where they attach the pumpout hose. Just take off the cap and the fitting on the hose will screw on. The other side is for fresh water. Hope this helps.
Good Luck,
Hamdog
rasbury,
Just to clarify, there is a water tank on one side and a waste tank on the other. You do not have two caps that say water..........
Thanks,
Hamdog
Get down in the bilge and learn, clean, service every hose/connection and fitting by heart. It's the life blood of your new water sled. Good luck. Mike
I never use saltwater to supply the head. Just too many microbes that'd thrive/morph in my holding tank with our tropical heat....... think, creature from the black lagoon. Or the little critter that jumped outta that guys bowels in Alien.
That said, and aside from the fact that no Admiral likes a sailor with a frozen seacock... I found all of my seacocks either frozen or nearly done and freed them with gentle lube and tlc. So, keep yer seacock lubed in case of an emegency....... or something like that..
And....why are there two threads on the same topic?
Mike
Brakes were no good for the whole trip? Someone's looking out for you! Good luck and you'll know how it all works when you're done. No short cuts allowed. With a 600mi trip behind you with no incidents you've most definitely used up your grace.
Westmarine has a toilet plunger looking hose adapter with an adjustable rod/prop that youd prop up against the intake from underneath, turn on the water hose and THEN the item needing a flush like the motor and a/c (separately). DON"T run the motor beyond 1500 rpm or it'll suck the hose flat even with great water pressure. let 'em run for 5-10 mins. Enginge water outlet is at the outdrive. The a/c outlet is on the starboard side above the waterline amidship.
Those intake hoses need to be double clamped and in great shape. You really don't want to experience a hose/valve/clamp failure/crack. Often over looked, these are a serious failure point that can sink a boat in mins.
I'd try spraying penetrating oil up into the valves from underneath and let it soak a few days then start to gently work them a little at a time. If they refuse to budge then that'd be another thread or some Google research on how to replace a thru-hull fitting.
Hope the Boat Tree is still a good spot. We may end up that way again soon. Cya, mike
If we're still talking about BELOW the waterline and you haven't pulled up the mattress bedding in the aft bunk behind the steps then a whole new world of challenges/headaches awaits you below that 18x12" lid. The shower sump is nobody's friend and they share a room with the two gate valves (A/C and Toilet) and another bilge pump. MAKE SURE that everything in here works flawlessly and is clamped correctly. It may be outta sight but if a valve/hose fails and the bilge pump running goes unnoticed for too long in here it's probably game over for the sea sled.
Have fun.
Mike
Do you guys leave you sea cocks open all the time or close them when under way? I would always close mine and I think that caused a slight leak at the base.
Good question Aero - I leave mine open - was never told different. Comments guys? MT
I think there is a placard in my lav saying to keep it closed while under way. I've been closing it ever since I bought the boat 3 years ago.
Mine are always open, I open/close them a few times a season for cleaning strainers.
