Reducing bilge water.
One goal I've had this winter is making an attempt to reduce bilge water. I've checked the bellows and all through hull fittings but nothing seems "leaky". One thing I did notice was the brass plug didn't have any kind of caulk or Teflon tape on it. Could that be the culprit? The boat will take on about a gallon or two per hour while operating and around 2-3 gallons after a week of sitting in the slip. Does that seem excessive?
Got a bore scope type wireless camera you can mount in the bilge while running if you cant find a possible source of water?
Y pipe, bellows, shifter cable, thru hulls, trim hoses, any hardware going through the transom ( trim tab sceews) are all possibilities as well as leaky manifolds, water hoses, etc
Yes you can fill your bilge with water to look for leaks, id only do this if i cant see the leak sitting in the water. Any spot water can get into the wood core, it will absorb it like a sponge and promote rot
Teflon tape makes less of a mess if youre removing every weekend.
RJY 8Mm Android Endoscope USB Borescope Inspection Camera Waterproof for with OTG and UVC Function 5M
I use teflon pipe dope on the threads. Teflon tape is not ideal for npt threads.
Rust will stop up pin holes in a leaky hot water heater!
You shouldn't need any sealer on pipe thread but things wear over the years.
Do you see light where the hull halves connect? Most, if not all of that should be above the water line.
