Bielge pumps
So, my 270 has two. Recently, the breakers for both are popping. So they must be getting power because they pop right? So I'd guess there must be a ground problem? Switch on the helm runs both but there are two breakers. Where are the grounds for the circuit? What do I need to check?
+ full time power
+ switch power
- ground
So this image shows pretty close what our set up would be except for the battery switch right? It also shows a fuse or breaker for the float switch that I don't think I have. So if I go to an all in one pump, what do I do with the wires that now go to the float switch?
Which one are you looking at getting?
Unless wired wrong they dont ground so they shouldn't trip a breaker unless they are running too long(sticking). If i forget my bilge fan it trips in about 4 to 5 min. I trip the breaker too many times a summer to count.
That plug is identical to the engine to mower plug on a Briggs or kohler or Kawasaki engine.
Even with heat shrink moisture can/will eventually finds a way in. A little bulb grease is insurance for when that happens. We boat in some of the most humid locations of the world.
I don't super like the white plugs, they give connection issues even on lawn mowers. Lawn mowers dont run in a wet/oily humid bilge.
Give enough slack where if they need serviced in the future you can pull the wiring out from under the motor to access it.
Let me finish my coffee/cereal and I'll send you a pic of what i do in that situation.
