Bielge pumps
2»
  • YYZRCYYZRC Member Posts: 5,380 ✭✭✭✭✭
    I love these heat shrink self solder connectors!
    https://youtu.be/7Wh5gM8GM70
    Those connectors are awesome never seen them before. Today is a good day I learned something.
    edited March 2020
    I got them on Amazon, lots of options for different gauges of wire.
  • rasburyrasbury Member Posts: 8,886 ✭✭✭✭✭
    You have to be able to get the heat to them to work, tight area like the midship bilge is tuff...use a little tourch? What kind of temp ?
    Heat gun works great.
    Looks like these would need more heat to melt solder?
    Cheap butane cigarette lighter works fine. Obviously dangerous on a boat.
  • PickleRickPickleRick Member Posts: 4,307 ✭✭✭✭✭
    Unless you have a diesel stick with the the old style.
    aaaah, think I will just use my butt clips and a lighter and call it a day...looks like the mid ship one is all I have to replace right now, will hang on to the other one until the other one goes...
  • IanIan Member Posts: 3,038 ✭✭✭✭✭
    edited March 2020
    Solder them. You are not needing to disconnect that often to have to have a disconnection point. Shrink over the top, as @PickleRick said you’ll get moisture in but less concerns if soldered and shrunk properly.
    edited March 2020
    Ok- I can't figure out these friggin wires...on the boat harness side I have three wires....one is hot, one is ground and the third I assume goes to the manual switch. From the float switch I have to gray wires, one still has a splitter on it I did not cut out and then the pump itself has a wire marked as positive and then  a black for ground...I can get the pump to run but the switch is not on and the float is not up- where do the wires run🤪
    I see diagrams for a on off switch and a float but it only shows two wires to get it done not three from the harness side...
    edited March 2020
    Post up a pic of all your wires and what is hot, ground and switch.  I'll see if i can tell what goes where. The wires on the pump are pretty standard.
    Does your pump have an internal float?
    This is a diagram I found on line and I think it makes sense...
    edited March 2020
    well it makes sense but does not work, at least completely...
    So, from the boat side I have a black wire (ground), Orange wire (hot) and then another wire I assume is for the switch.
    On the other side, I have a float switch with to gray wires, one of the gray wires has a splitter.
    On the pump I have a red and a black.
    So, assume the ground wire from the boat side goes to the ground wire on the pump so that takes care of those two.
    The diagram I found has tow circuit breakers which I do not have.
    So, I run my power wire to the splitter which goes to the pump and the float switch. The other wire I ran to the wire for what I assume is the switch, no were else for it to really go. It works off the float switch, but will not do anything off the help switch. Only power goes through the float, no ground....so I'd have a power side going to the help switch from the perko..**** I don't know, I can't figure out anything that makes sense....the ump should run off the help and the float for the mid ship pump right?
    I also tested the float for continuity and it functions properly...
    Can you post pics of your new bilge pumps?  Specifically the wiring?
    You keep saying your float switch has a splitter, im thinking your old pumps were 2 wire so the splitter was to the dash switch, bypassing the float to give 12v pos.
    Your new pumps probably have 3 wires.
    You need to use a multi meter or test light to verify you get 12v pos from the switch wire.
    You have 2 breakers? One for each pump?
    I have my 2 rear ones wired in together but my front one independent.
    At least post up the model number/brand of your new pump(even an amazing link), ill google the wiring and write/draw you a diagram
    thanks for the reply @PickleRick
    I have two breakers back by the battery switch...the pop out types...I looked this am real quick under the steering wheel as there is a mass of them there also that I have no clue what they are...but nothing was popped.
    The pumps look identical to the ones I took out, different brand and there are two wires.
    If you look at the diagram above you see a split on the power side....hot wire goes to the pump and the float and then a wire to the switch...which makes perfect sense to be but it won't run anything on the switch, just the float. I did not check that wire for power...I will do that tonight and I don't have power I guess I pull the dash apart and make sure I did not pull the wire lose or something....
    Did you wire the split on the battery side of the float stitch or on the bilge pump side?
    Sorry if that sounds like a stupid question, i want to rule our simple error.
    edited March 2020
    I don't remember! It would only work on the float one way, the other it did not...and with me, there is no stupid question s, just stupid answers...
    Make sure the splitter with switch wire is between float and bilge pump or it won't work without the float being lifted
    That was it, thanks bud- swapped the wires around on the splitter and Wala! Thanks @PickleRick
    edited March 2020
