Voltage issue - 2000 270 fiesta vee
Hi all, I recently purchased a 2000 270 fiesta vee. I am having an issue with voltage at the helm. Boat starts and runs just fine. Alternator is putting out 14.some volts to the isolator and then from there each battery is reading 13.some while running. But at the helm with the key switch off I get battery voltage taking the reading at the power port. When I turn the key on I am reading 1 or more volts less than the battery voltage and this is after the fuel pump cuts off. When I start the engine I am reading two volts or more below the battery voltage. I cannot figure out where to look to resolve this. All is working fine, but for example, my trim tabs move very slow because they are only getting 10 or 11 volts while the boat is running. I have tried unplugging some of the lines on the fuses to see if maybe I could isolate what is causing the draw, but nothing helped. Any ideas on how to troubleshoot this would be greatly appreciated. Thanks
First of all, I find it sort of normal to drop almost a half to sometimes a full volt at the helm power port. Running at idle I sometimes dip down into the high 11's, 11.9 - 12.1, but yours sounds more than that. The obvious places to check are all the battery cables and connections, as well as the grounds. The not so obvious one's are the connections at the battery switch (have to remove the switch housing to get to connections at the back) as well as the connections and grounds at the helm. If you unscrew the helm panel and take a look behind you'll be amazed at the mess of wires in there. I don't know if it's factory, but I also have a 12 volt receptacle on the back side of the locker/closet facing the v-berth. If you have one, check that too and if different than at the helm it can be another indicator of a bad connection somewhere.
If you're getting voltage at high rpms but not low idle rpms chances are your alternator is on it's way out so long as nothing funny is going on with the isolator.
So long as both your batteries are healthy and charged you should see 13 volts or more at idle while running. 13.5 to 14.5 is the sweet spot you want to reach
Also trim tabs move pretty slow, a little adjustment can go a long way so they are not designed to be fast but i bet 10 volts does push the pump slow compared to 14 volts.
Is the voltage gauge analog or digital
If anything it does seem like possibly bad connection or not so good connection some where. I was re reading about your slow moving trim tabs.
There was one from @Cableguy Greg for a 280 that should be close, and the link below is for a FV250 which looks just like the layout on my 270.
https://www.dropbox.com/sh/5hhpd27ogrbh19g/AADKiYf7KGmYEUeXyATWqtWga/Rinker%20FV250%202006%20wiring%20diagram.pdf?dl=0
https://rinkerboats.vanillacommunities.com/discussion/3038/280-ec-wiring-diagram
