2000 232 Captiva Horsepower
Hello,
I currently own a 1998 Festiva with a 5.7L V8. 92bbl, (non Vortec heads) I believe this engine makes 250 Horsepower. I am currently looking at a 2000 232 Captiva with a 5.7L Carb engine (mercruiser). I can't seem to find the horsepower or any performance specs for this boat such as top speed. The individual who I've been corresponding with is selling the boat for his dad and knows very little about it. I'm assuming the 2000 232 has Vortec heads. not sure if the carb is a 2bbl or a 4bbl. The boat looks great, I'm worried it might be under-powered. Any help with the horsepower or any other specs/ advice would be greatly appreciated.
Jim
Welcome to the Forum!! Someone on here might have the same or close model boat to help..otherwise a call to Rinker might be in order. Randy is the guy to talk to at Rinker, or possible Alswaggs on the forum here, you can send a note from the forum here too.
apparently, comments have to be approved if you're a trouble maker like me... :-) here is plain text of a link.. c&p it in your browser for all the information you can stand about your prospective floater.
http://boatinfo.no/lib/mercruiser/manuals/mercruiser24.html#/0
Merc did move to the vortec line in the late nineties, though.. maybe '98-'99?
We can't be for certain w/o seeing those bolts..
These engines are rev limited at 5200 rpm, and are likely to fly apart if ran over 4800rpm consistently... So.. the advantage of four barrels isn't as pronounced as marketers would want you to believe with these marine rigs... A matter of fact, higher ratio rockers for that engine would likely produce **** similar results, and could be done in an hour or so..
I think I'd be happier with the 2bbl... Seriously.. its likely a healthier engine compared to a 4bbl of similar age and use.
I'm all about ponies, and hair floppin around speed... but there is a cost to that.
this is unsolicited, I know.. sorry for the interruption.... it's a used boat.. I wouldn't want a high performance used boat, because it was likely used as such... when you own power, it's inevitable. :-D
The 5.7 sbc is a solid engine that will last a long time.. the thunderbolt, unless it's been tampered with, limits the engine speed to 5200rpm.. if it's a stock prop, it likely won't break near that limit, and likely closer to the much safer and dang near as close in power output 4800rpm.. a MPI/EFI engine is mucho better for longevity than a carb'd engine, as it trims and times according to environment- the carb, if well maintained, isn't a deal breaker... it will suffice. A 4bbl carb, as I said above, is a lot of smoke and mirrors in this application, but more to the point- you stand a pretty good chance of spinning that engine lean out of the hole and under WOT with a 4bbl, unless you up the jets- in which case you could wash it.. both are tough on an engine, and why MPI/computer controlled engines are superior... a carb simply can't monitor demand from second to second, and it's tough on an engine.. a two barrel carb is less likely to be capable of washing or leaning, so long as the carb is healthy...
I certainly wouldn't concern myself about the difference in rated output between a 2bbl and a 4bbl... like I said, the real difference is north of the rev limiter anyway.. If you really like the boat, and after a sea trial the thing could stand what you determine is minor tweaking for performance, the place I would attack it is at the leverage point, or the prop, more specifically..
