@YYZRC , your supposed to use special crimpers for the pins but you can use a a pair of needle nose pliers to bend them over, just try to overlap them when you do. If not done correctly with the pliers the crimp can be too wide to fit into the connector.
I don’t know but I think the switch can be off and the charger on to charge. With my 242 I always turned the battery switch off. With the 330 I want to get used to leaving it on like most do.
Speaking of these molex connectors, where do I buy some? I tried searching amazon but it was a nightmare of options.
https://www.ebay.com/itm/382691867903
