do you leave your house battery on when not at the dock?
Why is the fridge connected to the batteries and not the power panel like the range and microwave? When I leave for the week I switch my batteries to the off position to not drain the battery but when I return my beers in the fridge are warm. Should I keep the battery switch on while gone for a week and plugged into shorepower? Is the charging system going to keep my battery from dying?
Thank you!
Like most everyone here, I leave the boat powered up 24/7. I have green stickers on the panel next to the breakers I want to leave turned on and red stickers on the panel next to the breakers I want to leave turned off. Most of the breakers can be either way. But when I leave the boat, the stickers help me to set the important ones correctly.
Tony
Salt Shaker 342
Hard to imagine the frig can draw more than the charger can handle, unless: frig running constantly, charger not working correctly, or you have a bad battery(s). When my cockpit frig was 100% DC it worked fine on the charger. I might suspect the charger has issues.
I leave the batteries on when at the dock on shore power.
Don't really see a reason not to.
For what is it is worth, Alswagg recommended these guys for chargers:
http://www.charlesindustries.com/main/marine.html
