Coax for antenna/cable TV 280 express cruiser
2
    aero3113aero3113 Member Posts: 8,866 ✭✭✭✭✭
    edited May 2020
    Here you go @YYZRC , and free shipping. I just bought one, now I need to figure out what size TV to upgrade to. I think a 24” will fit pretty well.
    YYZRCYYZRC Member Posts: 4,946 ✭✭✭✭✭
    edited May 2020
    That is an amazing price!! $60 shipping tho :(
    Ah, that’s too bad. Free shipping in US for orders over $75.00.
    My new 3019 antenna arrived today. Seems to be better made than the original that is on the boat now.
    Does it come with the power supply?
    Yes it does.
    edited May 2020
    It has gain control also.
    Amazing!! Just dropped anchor and was able to install the antenna and amp without my wife getting mad, LoL! . I was shocked that it worked so good and how many channels we’re receiving!
    edited May 2020
    Wow!!! Amazing. Did you replace the cable from the antenna thru the arch to the fuse panel?
    I just ordered on eBay.
    No, it came with new cable but I didn’t replace it, yet....
    I will check back in 1/2 hour...!
    LoL!
    One thing everyone needs to do when receiving off an antenna is set the TV for “Antenna” or “on Air” not “cable” in settings.
    Put rag rats on for the kiddo . Nice goes right on the original mount. I get 6 channels with my antenna on the shore of CT.
    I see you have the same clouds as I do.
    She’s trying!!
    @reneechris14 , what antenna do you have installed? I highly recommend the 3019
    Its the original seawatch disc.
    @reneechris14 , maybe you should try the 3019. It’s supposed to pull in channels from 60-70 miles away.
    before you change the cable, just change the ends, very easy job to do, use good quality (gold plated) ends, and the wire in the middle ... sand off any oxidation, or re terminate it if you have enough cable slack. I doubt the cable itself needs to be replaced.
    Yea, I don’t think I have to change the cable since it’s working really well.
    Be careful sanding the center conductor on the cable. The signal rides on the outside and relies on it being clean. Scraping it or sanding it can cause some issues. If the signal is strong enough, you probably won't notice it.
    Woah, I didn't know that!  You mean the solid copper wire in the very middle of the cable?? How do they get the signal to only transmit on the surface, instead of through the full cross section??
    Most coax cable is copper clad steel. Riding on the outside of the center conductor is the property of the cable. The higher the frequencies, like 750MHz and up to 1GHz have less tolerance for any variations in the cable. I used to work in a 300MHz system and we could get away with scraping the black center conductor when it was analog. When we went digital and upped the bandwidth to 860MHz, all of that old cable reared it's ugly head with digital tiling, or pixelation. The digital data goes crazy when the medium isn't perfect.
    Huh, didn't know that. But when I reterminate the coax and say splice the end of the cable, when I cut through the copper wire in the middle of the cable, the full cross section looks like copper, doesn't it mean it's not copper coated?
    I ditched my TV antenna. Worthless IMO. Went with a DISH Tailgater system.
    tk1973tk1973 Member Posts: 120 ✭✭
    @Rk1985 so... did it help? I’m also in Cooks bay with the same boat and thought I would start looking into why I can’t get any channels... all original save for a digital converter box.
    Let me know how you fixed it when you have a chance. I’m stuck.
    Curious - what did you set the gain control at? I did about 3/4.
    From the pic I took, I set it pretty high.
    I wonder how much power this thing is using when not in use.
