Amazing!! Just dropped anchor and was able to install the antenna and amp without my wife getting mad, LoL! . I was shocked that it worked so good and how many channels we’re receiving!
No, it came with new cable but I didn’t replace it, yet....
before you change the cable, just change the ends, very easy job to do, use good quality (gold plated) ends, and the wire in the middle ... sand off any oxidation, or re terminate it if you have enough cable slack. I doubt the cable itself needs to be replaced.
Be careful sanding the center conductor on the cable. The signal rides on the outside and relies on it being clean. Scraping it or sanding it can cause some issues. If the signal is strong enough, you probably won't notice it.
Woah, I didn't know that! You mean the solid copper wire in the very middle of the cable?? How do they get the signal to only transmit on the surface, instead of through the full cross section??
Most coax cable is copper clad steel. Riding on the outside of the center conductor is the property of the cable. The higher the frequencies, like 750MHz and up to 1GHz have less tolerance for any variations in the cable. I used to work in a 300MHz system and we could get away with scraping the black center conductor when it was analog. When we went digital and upped the bandwidth to 860MHz, all of that old cable reared it's ugly head with digital tiling, or pixelation. The digital data goes crazy when the medium isn't perfect.
Huh, didn't know that. But when I reterminate the coax and say splice the end of the cable, when I cut through the copper wire in the middle of the cable, the full cross section looks like copper, doesn't it mean it's not copper coated?
@Rk1985 so... did it help? I’m also in Cooks bay with the same boat and thought I would start looking into why I can’t get any channels... all original save for a digital converter box.
Let me know how you fixed it when you have a chance. I’m stuck.
I just ordered on eBay.
