Alignment bar wont touch splines...
EDIT - ignore this first post, finally got the bar to go in, but it required a LOT more force than I thought it would..
Another day, another surprise...
This is in relation to another post where I'm trying to track down a noise that's coming from the transom. Best guess was out of alignment or bad bearing.
The bearing turns nice and smooth and does not move back and forth, no grinding at all.
This is the tool that I am using. https://www.amazon.com/gp/product/B07NCQ1TWN/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Main concern:
Grease the far end of the bar, put it in, it goes smoothly in till it hits something, but no matter what you do, the grease on the end remains untouched.
Secondary concern:
There is space between the FRONT (bow side) of the gimbal bearing and whatever it is supposed to mate up to on the transom assembly. IS THIS SPACE SUPPOSED TO BE THERE? It's about 1/2 inch.
Possiblities:
Incorrect alignment bar?
Bearing is too far back and was not pushed all the way in?
Motor is too far forward? (I don't see how this is possible, just throwing it out there).
I dont see #9 in there... which I hear is normal for sealed bearings..
https://www.marineengine.com/parts/mercruiser-sterndrive-parts/bravo-three/0f730000-thru-0m100000/gimbal-housing
Main concern:
Secondary concern:
Possiblities:
Post edited by J3ff on
Push the alignment bar in just up until the point you don't touch the coupler.
Then move the gimbal up/down/left/right until you can slide into the spline of the coupler. Sometimes a little wack or jerk will give you the feel for what it takes to move her.
When aligned you should be able to easily slide it in and out of the coupler with 2-3 fingers.
You should see even spline grease all around the tip of the bar.
So, yes shes off. When you start adjusting make sure you count turns on the nuts of each side. This makes adjustments more calculated. It's also easieir to get back to start position if your adjustments make it worse.
I've never heard of the loweing past fitment then raising back up to fit technique until your pontoon thread, makes sense. Less likely to come out of alignment when you snug the top nuts. Keep that in mind when getting it centered.
Have to think about that lowering first thing... can you tell if this is sealed vs non-sealed?
The oem bearing comes with a grease plug to plug the grease fitting if the outdrive is older and being updated
When I forced it in, with NO grease on it, it came back out with grease only showing contact on the top... wouldn't that mean you lower the front and the top splines will be LESS in contact? Going to go look over some diagrams
This all doesn't matter because I lost the new gimbal bearing!! (ha ha) Another one will be here monday and I'm sure I'll find the 1st one within 5 mins of it showing up!
Here is the washer he talks about. My inline 6 is easier to access than your v8 but maybe this will help you to see what you're looking for. It does appear to be a about a 1/16th thick.
And yes, if splines are heavy on top and not present on the bottom it needs to be lowered.
Heavy on bottom and low on tops they need to go up.
If you see washers on the back mounts start lowering
From my experience with a 23 yr old alpha, I found I was missing the washer on one rear mount, the front mounts required being near bottomed out to align. Took removing the motor to find the missing washer sitting down inside the shield.
She aligned without it, but barely. Once put back it fit much better. With these v8s you don't see the mounts without crawling or a good bore scope.
the grease thing is BS too... UNTIL you get near 'right'. it will lie like a winter bear when it's way out. when it's close? yeah, depth of grease on the rod as made by the splines is invaluable. at first? good luck with that... it confuses far more than it helps.
yada yada yada.. that isn't helping you... this may:
use a light mallet. push the rod in as far as you can but no more- just enough that it 'holds itself' when you let go....
now carefully- very carefully.... sit parallel to the hull facing and watching the end of the alignment rod... use a tape measure if you must... but.. TAP it lightly. nothing? do it again... nothing? do it again... and again... at some point, the END of that alignment rod will either RAISE or DIP as it uses the bevel on the end to go in... once you see whether it dips or raises? adjust the engine to accommodate better alignment...
yell to your assistant to either raise or lower the mounts. ONE FULL TURN. no more. no less. both sides.
now, remove the rod and start over.
at some point you'll likely discover it's not only rises or dips, but it will also move closer to you or further away (if you were looking AT the transom you'd see the end of the rod move left or right and a little matters.. )
if/when it pulls left or right, you have to turn one side up a little more than the other... but here is the thing: when you see that? you're getting near the sweet spot..
you'll discover you get the rod in further and further every cycle before it dips or raises... you DON'T care how hard it is to shove in there or pull out yet- you SIMPLY WANT TO WATCH IF THE END OF THE ROD DIPS OR RAISES the further in so you know which way to adjust...
then, miraculously, you bottom out. you'd think you pull the rod out, but... no... you try- and as soon as it start to move you stop and have your assistant continue what they were doing... if they were raising the mounts? have them continue upward... if they were lowering? same- keep going down... FULL TURNS.. precise... use a marker on the nut and the post if you have to.. have them turn it, and you pull on the rod- if it slips out a little, reseat it and have them turn again...
you'll reach a point where that rod comes out pretty easy... not two friggin' finger easy, but pretty dang easy... guess what? NOW you're 'close'.
start turning in 1/8 turns....
yada yada blah- you get it from here....
when it's right? when it's 'perfect'? the rod has equally depth grease marks on the shaft.... and it is never easier to move ALL the way in and out... you'll know that because you went past 'perfect', and you go back down IN FULL PRECISE TURNS after you KNOW it's 'harder' to seat and retrieve.. then you sneak back up on it in tiny turns....
it took me longer to type that than the alignment takes right up to the paragraph right above this one.... once you're 'past' perfect and drop FULL TURNS to get back under it, the 'creep' takes a while. it's the most time consuming part of alignment other than pulling and re-hanging the outdrive.
Good instructions @212rowboat
When the bar is in twisting will let you know the pressure also.
