I don’t like all that weight on my boat on jack stands so I put it away around 1/4 full. I only use valv tec fuel which is stabilized so I don’t add any more for winter
Actually I forgot about all the different situations. Indoor and temp controller then low fuel. Outdoor full enough not allow too much expansion. Fuel stabilizer no matter what though.
Another one of those questions with many opinions. I leave low, about 1/4 and with stabilizer added. Mechanics suggestion and true, low fuel means more fumes that means more volatility but I am inside and up here it’s much warmer once I am out. Reality - if something blows in there we’re all toast anyway..
More importantly, in either case use non-ethanol fuel! I still prefer 1/4 tank or less. If the fuel does get contaminated - much less to deal with. Add a bunch of fresh in the spring.
So, safe to say: inside low level, outside high level then? Still confused
I was told keep the level low irrespective. In theory lower temperatures means potentially lower fumes in the tank where as higher temperatures outside as it warms up under the wrap may create more fumes thereby not as safe, so again in theory a full tank is better - less gap for fumes to build up. But then it will vent out and if vent covered by shrink then it's will go back into cockpit/cabin. The temperature fluctuation outside may also create more condensation in tank especially if non non-ethanol.
So as @Aqua_Aura asked, more info where you are and the storage plan would help to reduce the number of opinions but you won't get a straight answer!
Jealous! I would love to trailer the boat out that way and spend a month exploring the area, and then boat back up the Trent. Maybe next year if C19 is still a thing and I can “work from home”!
I try and leave my tanks close to empty for storage. Water levels are always hit or miss in the spring so don't want to be extremely heavy. It also would take me a good month or two to burn through a full tank of fuel and don't want to be running last years gas in July.
With the storage issue out of the way I'm wondering if anyone can answer another question(s) for me? Info: 2001 Rinker 340. 235 gallons. 2 tanks I think? or one big one with a baffle? It has a gas filler spout on both sides as well as 3 valves in the line running on the firewall. The starboard side valves are both open and engines as well as the generator run from these. The starboard side valve is off. Both fuel gauges were sitting at 3/4 full when we brought the boat home and both are now sitting at just above the 1/4? If these tanks are in fact separate shouldn't these gauges have different readings? Not understanding this? If both engines have been running off the starboard tank this doesn't make sense to me. It does however list a little to the port side which could mean that the port tank is more full??? Any suggestions would be welcome. Taking the boat out Friday
Thanks so much. So do both fuel gauges read from only one tank then? And judging by this diagram on the link I should be feeding the port engine from the port tank, with the middle valve closed and the starboard and generator (genny is on the starboard side) then??
Yes, you should feed port tank to port engine and starboard tank to starboard engine (with the genny thrown in also).
If you have it configured like the drawing - and use your engines about equally (no genny running) they should use about the same amount of fuel per hour.
Running the genny is about the only thing that would throw off your levels.
You can disconnect it from the pump and it should drain that way. Also there is a strainer on the pump in that same area that could probably use some cleaning as well.
To empty the fresh water holding tank you just turn on your faucets and let it drain overboard until empty. There will always be some water left, that's why you also pour in anti-freeze and run that through the system until it comes out of your faucets (all of them). Make sure you use a non-toxic formula made for fresh water tanks.
I don’t like to put antifreeze in the tank, it takes half the season to get it out. If there’s a little water left in the tank it’s ok, it won’t hurt anything. I’ve been doing it for years. You need to pump antifreeze through without using the tank. Make a line from the pump and use it to suck antifreeze direct from the jugs.
Lots of opinions on full or empty for storage.
Fuel expands a lot on warm days & pukes excess out of the vents.
Huge fire up our way at a boat storage facility in late 2011.
$40M in damages, 75 boats & some antique cars.
https://youtu.be/pskTjakcyb0
https://rinkerboats.vanillacommunities.com/discussion/11662/gas-tank-valves
