Of course you @aero3113 have pictures. You need to just put this all together and make a boating how to manual.
I should! Whenever I do anything on the boat I like to take pictures, and have them for reference. There’s been times when I’m looking back at the pictures, I find something else that needs attention.
I disconnect my line from the pump and let it drain into the bilge too. I don't put anti-freeze in the fresh water tank either. Just let it drain down as low as you can. I have the Campco tank kit and hook that to the fresh water pump and pump it through all of my lines.
The bottom of the tank freezing would be no different than an ice tray in the freezer. As long as there is room to expand it shouldn't crack and ice trays do this daily. Now I'm not saying to leave the tank full but a few inches of water shouldn't be an issue, if it's even a few inches probably less than one.
Thanks everyone for the advice. To simply buy a "boat with a washroom" like my wife has always been saying certainly wasn't as easy as just " buying a boat with a washroom" .......
I agree with @Aqua_Aura alittle standing water is ok but water that is confined (like in a hose) will expand and crack. So get as much out as the pump will allow.
And the other part of that is I always took the two lines off the hot water tank and joined them so that as anti-freeze is running through the system you're not running it through the tank. Takes forever to get the smell out if you run it through the tank. Just like the freshwater tank, just let it drain. Don't forget to open the vent so it drains easier.
I ran 2 gallons through the AC by pouring it into the strainer (seacock closed). Couldn’t see the output. Does this sound like enough? I also flushed 2 gallons through the toilet.
Do I need to backflow antifreeze thru the bilge pumps?
Give it a little tap with a hammer or screwdriver handle. It should stop leaking.
