Dimension and thruster advice/help 340 Fiesta Vee
2»
    @LaRea How could you possibly miss this???
    edited January 2021
    Sealed lead acid batteries are acceptable for my set up. Vetus says that if the battery is going to be positioned with the thruster, a sealed lead acid (they call it their smf) or a sealed agm should be used.
    I can’t imagine vetus would recommend anything against abyc, Grahamu could you post the details? I’m up for a new battery and would like to see the reg before I splurge on an agm. Lead acid works just lovely. Thanks
  • Dream_InnDream_Inn Member, Moderator Posts: 7,769 mod
    @LaRea I'm sure it's AGM. Mine is.  I had to replace it a few years ago. Hard to believe, but it was original.
  • GrahamuGrahamu Member Posts: 894 ✭✭✭
    @Liberty44140 I will try and find the regs tomorrow at the shop and also check with the electrician who is ABYC certified.
    It appears I am wrong I just checked and the electrician says ABYC does not object to "sealed" lead acid batteries, sorry about the misinformation.
    Thanks! Great, Glad to know the right options for purchase.
  • YYZRCYYZRC Member Posts: 5,334 ✭✭✭✭✭
    I went with an Optima Yellow top just to be safe.
    Fist day back on the boat yesterday, was glorious. 41 degrees cold inside storage and 9 degrees outside.
    I took a look at my thruster battery box as I was curious about venting. I have to give cruisers yachts credit. There is a thru hull coming in to the box and a hose connected venting the box outside. I was wrong, there are no vents in the box, but it’s vented to a grill on the hull of the boat. You can just barely see it in the pic I posted. Lower left corner of the box.
    Cruisers makes a really good quality boat. I’m not surprised it’s done right.
