Moving To FLA- Need Boat Recommendations
rinker270nb
Member Posts: 207 ✭✭✭
We are nearly locked into a home in Bradenton / Lakewood Ranch. Now, I have to figure out my boat situation. Keep or sell my 99 Rinker. Likely sell, then find a center console to rack and trailer? I will fish a lot, family likes to do a full day at the sandbar / beach. Would want some creature comforts. Would like to take to other parts of FLA.
Thought I'd get recos from here, you guys seem to know a thing or two about boats .
If you like the 270 and you can fish comforably off her she will be great for the family. Dont force a trip out if the weather/waves are worse than forecasted. Change your plans to some protected fishing spots instead. Your family will thank you.
I wouldnt hesitate to run my single screw to the Bahamas and back if i had the time and weather was right.
I rent some pretty beat up single motor 20 to 22 footers every summer and fish from 100 yds off shore to 10 miles off shore.
https://cannons.com/boat-rentals-sarasota/
I'm hunting for a 26+ twin 250 CC, just add it to my mortgage. WTH is up w home insurance prices in FLA, dam!
https://www.perfprotech.com/mercruiser-gm-50l57l-v8-fresh-water-cooling-systems/category/1291
There is going to be scale in the cast iron block even if run in fresh water only. Putting antifreeze in it will cause the rust to flake off. Those flakes will then clog up bottle neck passages in the block and in the heat exchanger. Think of what a rusty fuel tank does to a carburetor on an old motorcycle, car or lawn mower.
The salt water will take years...a decade or more to eat through a cast iron block but only 3 to 5 years on the manifolds/risers. That is with flushing properly and regular use. Just run on ear muffs after running in the salt.
Unless you tear the block down to heat tank it I'd change manifolds regularly and run as is until she dies. Then install closed loop on the replacment motor.
A walk around will enable the family to go down below while you brave it out.
Even when it's 90 degrees out and water is 85 degrees I get cold out in the rain. Im hard top how do I don't care what the weather throws at me but i used to keep an insulated rain jacket and snorkelling goggles on my sailboat. Kept me warm and being i had no windshield i could still see while keeping my bow into the waves/wind.
The thing you have to be where of buying down there is. did the guy take care of it. Meaning every time it is taken out, was the engine flushed out. Some people down there have so much money, they don't care. They will just buy a new one.
Salt water so harsh, new friend I had meet, down there. bought a used 25 hp for a small fishing boat, it only had 100 hours on it. He brought it home. Installed it. Found water was not circulating. So he put salt away in the engine. That broke up all the salt deposits. However it clogged up all the passageways. And he had to take it to the shop to be completely torn down and repaired. Cost was almost as he paid for it.
Not trying to scare you, just educate, as if I had not lived there for 3 months I would not have known either.
The coldest fishing day we went out was with Handy it was 42in the am, first part of January. But it quickly warmed up to mid 50's. Not that bad. Just need a jacket. He will say different because he is a soft FL guy now.
https://www.regalboats.com/model/42fxo-yacht/
