Hot water heater
aero3113
Member Posts: 8,826 ✭✭✭✭✭
How hot should my water for the galley get when it's being heated by the engine (Raw water cooled)? If I go on a 1.5hr journey should the water be HOT or would it be just warm?
I would remove both lines going to the water heater and blow thru it. It should not take much pressure to get thru (try both directions - blow thru each hose). You could also try an air compressor to see if something dislodges.
Is your engine raw water or fresh water cooled?
I'm assuming if you have a water heater bypass, it is now turned correctly? If you get hot water using electric, then it has to be.
2001 310 Fiesta Vee
T-5.0 FWC Mercs w/ B2
