Water accumulator tanks -- pro's and con's
13»
  • LaReaLaRea Member, Moderator Posts: 8,066 mod
    OK, Handy inspired me to do my homework.
    Jabsco PAR-MAX pumps come in two flavors.  The cut-in/cut-out pressures can be either 10/25 psi, or 20/40 psi.
    The Jabsco accumulator tank is rated for up to 125 psi, but the default pressure from the factory is 10 psi.  That would work fine with a 10/25 psi pump, but not with a 20/40 psi pump.
    I apparently have a 20/40 pump, so the best bladder pressure would be 20 psi (set with the water pump off and no water pressure in the system).
    A 30/50 pressure switch would require 27 PSI in bladder tank for example
  • Dream_InnDream_Inn Member, Moderator Posts: 7,924 mod
    I thought I'd bring this post back up so Handy could laugh at me!  (not really, but I know he will)  I just ordered the Jabsco 1 liter accumulator and some flex hoses.  After being away from the boat for the winter, that pump is just too loud and annoying.  I'll post some pics when I get it installed.  I'll have to think about where I want to put it, but I'll probably still try under the galley floor where the pump is.  But I'm gonna look in engine room as well since the pipes are back there as well and easier space to get to (but, under floor will allow me to mess with mounting of pump while I'm there).
    Why laugh?
    I do like having that accumulator tank.  It would be nice to have an even larger one, if I had room for it.
    How about 2 inline?
    Yeah its basically an expansion tank in a boiler loop per say. Keeps the pressure regular. Definitely a good idea.
    Boat Name: Knot A Worry
    Now I'm wishing I had looked just a little bit more before I ordered.  I saw a 2-gallon one with decent dimensions (13" X 9" X 9" - so actually less height but bigger cube instead of 15" X 5" x 5") instead of just a liter.  It had nice mounting as well and was only 43 bucks shipped.  I definitely had the space.  Oh well, we'll see how this one goes.
    Jabsco one may be worth the extra just because of the fittings.  Of course, you get the smaller Jabsco with the correct fittngs for $54.
    http://www.go2marine.com/product/160328F/jabsco-accumulator-tank-mini-tank-30573-0003.html
    I like the correct fittings.  Of course you could just get the smaller Jabsco with correct fittings for $54.
  • YYZRCYYZRC Member Posts: 5,419 ✭✭✭✭✭
    I installed the tank, will pressurize as per @LaRea’s method of trial and error.
    You will be very happy with your purchase.  I still think about and like the one I have.
    @Dream_Inn, remember you commented last weekend that my accumulator tank didn't seem to be working right?  I just discovered that the bladder has ruptured.  I went to adjust the air pressure, and water came out the air pressure valve.  So the tank lasted six years.
    edited August 2021
    After installing the new one, I opened the old one ... sure enough, ruptured bladder.
    Well that looks nasty
    Interesting I always wondered how those work, rubber bladder makes sense. My dad always swore by those on his sailboats but I’ve never had one…
    Well, 6 years isn't terrible I guess. I know it's well worth having. I just talked someone last weekend into installing one.
    I would have got a bigger one if possible
    I saw a 2-gallon tank that would have been really nice, but I don't have space for it.  Also it was around $200.
    How about a one gallon?
    I probably have enough room for the 2-liter tank by Whale, but I didn't feel like re-working my plumbing.
    Anybody considering adding a tank:  anything smaller than 1 liter is probably a waste of money.  And if you have space to go bigger than 1 liter, do it.
  • Aqua_AuraAqua_Aura Member Posts: 2,702 ✭✭✭✭✭
    edited August 2021
    I was looking at other Jabsco pumps such as the washdown pumps that have impellers rather than a diaphragm. Seems they would be much quieter and also pump more water for better water pressure especially at the swim deck washdown (mine seems weak) the rest of the faucets have good pressure. I guess the biggest benefit would be the noise level.
    The washdown pumps are not approved for drinking water but we don't drink our tap water.
     Anyone have any thoughts?
    If it has to much pressure it can cause problems with your plumbing.
    2002 Rinker FV 342
    The purpose of the tank is to lessen the pump runtime.
    How about this tank?
    It would probably work.  It's gonna weigh 20 pounds, so you'd have to be careful about mounting it.
