Horizon 900 Chain Slipping
rmrstlmo
Member Posts: 237 ✭✭✭
The windless works fine going down but the chain bounces considerably when bringing the anchor up. So much so that it doesn't always come up. It seems the spring on the flapper needs to be stiffer. The previous owner was having problems and he might have replaced the spring. I ordered a spring from P2 marine and it does the same thing. If I hold down the flapper with a piece of wood while the admiral brings the anchor up it works as it should. Has anyone experience anything similar? Ideas for a fix? Thanks for your help!
Ray
2006 390
Previous 2000 340
This is the control arm
Does anyone have the links for the spring and or the gypsy. I don't see either one specifically for the 600/900
Good to see this post as this may turn out to help others.
Also as LaRea said, the gypsy could be worn & just not be able to attack the chain & line.
And YYRZ correct that previous owner replaced anchor line & rode with new. Wrong size replacement would be super easy.
Ray
2006 390
Previous 2000 340
I am gonna add a swivel to the anchor/chain connection, add washers to the control arm pin to take up some slack and then possibly see if I can turn the gypsy 180 so the slight worn portion that grabs the chain will not be an issue. A few small fixes for hopefully a large correction.
@rmrstlmo I notice you have washers on the control arm pin, did you do this?
I've got a Mantus S1 swivel. Awesome stuff.
I've been working on a fix.... Besides the obvious fiberglass work that needs to be done I'm going to bolt to a stainless steel plate on the inside.
Ray
2006 390
Previous 2000 340
I'm pretty sure that anchor roller is way too small for your boat, and it's definitely not mounted correctly. The way it's mounted, I'm amazed that it never failed until now. I'll measure mine today, and post some pix with dimensions.
For sure, I would not re-mount it the way it's mounted now!
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
I am gonna have to look closer at mine as it also seems very far forward and this is factory installed. I know I have seen other Rinker and the plow point is much closer to the bow.
LaRea - your measurement of anchor tip to bow would be very helpful.
Ray
2006 390
Previous 2000 340
I'll get you some measurements and better pix.
Ray
2006 390
Previous 2000 340
Someone saw that on my boat and then told me how they were anchored and the bolt worked it's way lose and they drifted and ended up on the beach. Just figured I would pass that on.
@YYZRC I have the same anchor roller you have.
@LaRea - Do you think your measurements would be similar to what @YYZRC is showing?
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
