Horizon 900 Chain Slipping
2»
    I thought they came factory with the plow anchor. 🤷🏽‍♂️
  • rmrstlmormrstlmo Member Posts: 238 ✭✭✭
    I finished my anchor roller repair this past week.  Ended up moving the roller aft about 4" - thanks for the help with other pics.   I cut out the damaged section of plywood and fiberglass, Epoxied in new plywood with new fiberglass over the top.  On the inside I used a stainless steel plate (see pic) to bolt through instead of washers.  I've been letting the epoxy cure for a few days so I haven't actually tried to use it yet.
    Ray
    2006 390
    Previous 2000 340
  • aero3113aero3113 Member Posts: 9,586 ✭✭✭✭✭
    Nice work @rmrstlmo !! I think the bow will crack in half at the windshield before you lose that pulpit again!!
  • YYZRCYYZRC Member Posts: 5,359 ✭✭✭✭✭
    Looks great and indestructible!
    @aero3113 did you notice the plate has 3113 printed on it?  I can't make out the earlier text but it might say "RANDO"?
    I hadn't noticed the 3113.  If it isn't stainless I'm not going to happy about that!
    Ray
    2006 390
    Previous 2000 340
    edited July 2021
    3113 is designated as hot rolled steel and not stainless however hot rolled steel is generally not shiny like that so the 3113 may not be referencing the type of steel 🤷🏽‍♂️. It looks like stainless to me.
    I was told it was stainless and it went through drill bits like it was stainless.  When I bought it was sitting in open air and there was no rust at all.  The other steels at this place were pretty rusty.  I'll keep an eye on it.
    Ray
    2006 390
    Previous 2000 340
    @rmrstlmo you should add a small starboard plate between the end of the anchor roller assembly and the anchor locker to prevent chain slap on your fiberglass.
    It might be hard to see in the photo but there is a 1/4" piece of starboard under the entire anchor roller and extending to the anchor locker.
    Ray
    2006 390
    Previous 2000 340
    LoL!!
    Good looking repair.
    Do it right or don't do it.
