Windlass overheating?
Aqua_Aura
Member Posts: 2,540 ✭✭✭✭✭
Horizon 600 Rinker 280
We pulled anchor in 15 feet of water and it was not stuck on anything yet the windlass would slow down as I pulled and if I let off the switch for a few seconds it would then pull normal then slow down. Finally got the anchor in but the breaker at the helm did trip about a foot short and it would not reset for about 15 sec. I guess maybe the breaker was still hot?
After we got it in we then docked and I removed the chain from the gypsy and ran the motor under no load and after about 15-20 sec it would begin to slow down like it was being loaded. Let off the switch for a few seconds then it would speed up again.
I am thinking the motor may be going bad and overheating itself or less likely maybe the helm breaker has an issue as it did trip and took awhile to be able to reset.
Any thoughts???
Any thoughts???
I'll remove the motor tomorrow and give it a look. I'll have time to check the connections as well. Seems like if it was a bad wire it would be a constant problem though.
When I get to the boat I can check connections for corrosion. If that's the case I could be getting resistance causing the motor to overwork.
I just remembered that my house battery hasn't been that great lately so that may be my issue. I will get that replaced regardless and also check my connections. Even with the engine running that's a big load on the battery especially since it's so old.
I use the windlass to pull me back to the deeper water before I drop the drives and go. I've never had an issue with either the 330 or 350 windlass being able to do this?
I also don't cleat the anchor rode. Not underway, not anchored. I've had 50 tons of boats hanging on my windlass without cleating the rode (yes, in light winds).
First, it's a 700-pound windlass. The load needed to pull my boat forward in light wind/current is only 50 pounds, maybe 75 at most (10% of the load capacity). The windlass can handle it.
Also, I typically run the windlass at a 50% duty cycle: On for 5 seconds to pick up slack, then off for 5 seconds while the weight of the chain pulls the boat forward. It's not a heavy workout for the windlass. The only time I use the engines is when the windlass can't get the anchor unstuck from the Potomac River mud.
