Ongoing Battery Charger / Refrigerator Challenge on FV 270
aconthelake
Member Posts: 15 ✭
On acquiring this boat in 2018 it had a ProMariner ProSport 12 onboard battery charger installed. One bank to the starter battery and one bank to the house battery. The ProSport distributes up to 12 amps between the 2 battery banks or to which ever battery needs power. The boat was left at the dock under 120V, the battery switch set to 2 (house battery) and the refrigerator running off the house battery which was being charged by the charger on shore power. All was well in the world.
In late fall 2020, I arrive at the boat after a month or so away, to find both batteries dead, the charger with no LED's on and a puddle of water below the refrigerator which had defrosted. The only replacement charger I could find was a NOCO Gen Mini 2 8 Amp which pushes upto 4 amps per bank to 2 banks. I installed the charger, both batteries recharged and all was well again.
In May this year, I finally got to the boat after the winter away to find the house battery very low and a new puddle below the refrigerator (which cuts out when the voltage gets below 10V). Once the engine started, I used the boat and the house battery was working properly again.
I came back in late summer, after leaving the boat on charge with house battery selected to run the refrigerator, to find the house battery virtually drained and the puddle again. It had been very hot and my mechanic guys pointed out that if the refrigerator pulls 5 to 6 amps when the compressor is on, the charger, which is limited to 4 amps max, would not be able to keep up. Made sense. So I installed a NOCO Genius GEN PRO 10 x 2 Fully Automatic Smart Marine Charger, which pushes out 10 amps per bank, more than enough for the Refrigerator needing 6 amps when running flat out.
After 4 weeks away, I return to find .... yes, a flat house battery and a puddle. The "Smart" NOCO charger had decided that house battery was faulty, as it could not hold a charge (refrigerator constantly pulling 6 amps?) and so it switched off the bank charge and allowed the refrigerator to drain the house battery.
I had the new (1 year old) house battery checked and it was good.
Any thoughts would really be appreciated. I have set the battery selector to off, emptied the refrigerator and turned it off and I go back to the boat next week to see if the charger has got both batteries charged. BTW, the starter battery has been fine throughout.
Many thanks.....
Many thanks.....
For two weekends in a row - coming down to the boat for the weekend, my house batteries are dead and the charger has decided to NOT charge them. This is the exact charger on my boat right now. https://www.amazon.com/gp/product/B08G3STB1N/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Talk about a stupid design, it just decides the batteries can't be charged and turns off. wtf. The house batteries are group 31 deka batteries, less than a year old.
I am replacing it with this one ( https://www.amazon.com/gp/product/B003JSJS5I/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 ) as it's sitting in storage doing nothing. Hopefully this one wont turn off for no reason. If it does, well... it's off to the junk yard with both of them. ( dont understand how a company could make a "smart" battery charger that decides to just stop charging on a whim.. sounds like they are faulty if you can't trust them to keep the batteries topped off.
The problem is that you show up to the boat after a week or so and the house battery is dead because the onboard battery charger stopped charging (for an unknown reason)...
this has happened twice to me in the last month. Cannot figure out why the 'smart charger' decides to stop charging my house batteries, but it does...
I need a stupid charger that just does it's job, if it had wifi (not bluetooth...need it to tell me what's up from 40 miles away) that would be amazing!
Thanks to all for the really rapid replies. I'll check out your recommendations but I also would like a "stupid" charger that just charged. I guess you don't want it to boil the battery but my old ProMariner seemed to do the job. WiFi would be useful as I'm 600 km away from my boat.
Battery charges don’t last for ever which is likely why the first chargers crapped out, if that’s what actually happened. A replacement charger should be sized to match the number of battery banks and how much of a charge you need. A “stupid” charger will simply ensure you keep buying new batteries.
As for the batteries… how many do you have, are they 6v or 12v, and how many amp hours of storage you have are all critical details you need to understand before you can start to solve your problem. Lastly, are the batteries true deep cell batteries or marine starting / deep cell batteries… as they are not the same thing.
It is only recently that wi-fi and Bluetooth have been available and will be a useful tool to monitor your boat. But in my mind that is a backup and you need to ensure that your systems are capable of keeping your boat afloat regardless of external communications. You both have a problem with charging your house battery and charger shutting down which suggests that the charger is not meeting the demand on the battery. If you want peace of mind, have the amperage draw of the fridge and what ever else would come on in your absence checked and double it and invest in a charger to carry that load. As i said earlier I have a Pronautic 1240 and am impressed with it. On my last boat I had to fill the batteries at least 3 times a season, this year not once. Wi-Fi and Bluetooth will become very useful for monitoring but not a substitute for proper systems. Sorry for the rant but all meant in good faith.
The question is, why does the charger think the house battery never reaches full charge? You said the battery is a year old -- have you topped off the water? Is the charger seeing a voltage that isn't accurate because of a loose connection or corroded cable terminal?
Have you measured how much current your boat is actually using? Maybe it's more than the 10 amps your charger can supply.
And seriously ... I wouldn't leave a fridge running unattended for 6 weeks. That's just begging for trouble!
Another thought: My house battery bank is 2 x 6V golf cart batteries in series. I just noticed in a ProMariner brochure that if you have 6V in series or 4D or 8D you have to call them. Anyone know if the 2 x 6V may be the problem with these newer chargers?
Understanding Battery Configurations | Battery Stuff
Which now makes me remember reading a review that said these chargers don't do well in that setup... hmm.
Either way, in the eyes of the charger, it's just a big 12V battery bank. If you look inside a single 12V battery, it's just a string of six 2V battery cells connected in series. The charger is like a honey badger: charger don't care.
I had a NOCO charger hooked to 2-6 volt golf cart batteries on a previous boat with no issues. I’m not saying it’s absolutely not the charger, but suggesting that you should make absolute sure it’s not the batteries.
Good luck to both of you guys, this would be frustrating for sure.
