Help me settle a dispute...
 J3ff
                    Member Posts: 4,170 ✭✭✭✭✭
J3ff
                    Local place here special ordered me a belt for the motor, based on my serial number. 135 bucks - it doesn't fit, it's too big.. they told me "too bad so sad" and that I must have removed something or have it routed incorrectly.
I normally go with the gates 30 dollar amazon one, but my last one got chewed up by an idler pulley and I decided to go with the normal one. Now I have a worthless to me 135 dollar belt.
The one they ordered me, based on engine serial number is part number 57-865615-003
This results in the below photo:
This is the gates 30 dollar belt, in this one the tensioner is not even half way up the channel, in the other it is all the way as high as it can go:
So the question is - do any of you know the exact part number for the 383 fresh water cooled mercruiser??
This is probably going to escalate to the credit card charge back route... I have not had good luck using the serial number to buy parts, but the SMUG guy behind the counter wasn't listening to me. Now they are trying to tell me it's my fault. Good luck with that!
According to the Mercury Parts finder site, 865615-003 is an old number. That has been superseded by 865615-Q03
if the shop ordered the belt, which is obviously wrong, then it’s on them to make it right. You can use marine engines website to punch in your serial number to see what the right belt really is.
What is your serial # I will check with that
https://www.oreillyauto.com/detail/c/micro-v/belts-hoses-16454/belts-16521/belt---serpentine-type-12828/eebb7a080a6d/gates-micro-v-serpentine-belt/gamv/k061049
Edit:measured it, came out to right about 107 inches give or take a half an inch.
Not sure why it doesn't work on my engine.. I guess it's time to start measuring diameter's of pulleys?
Eyeballing it, everything looks correct?
Stock photo, notice the little rounded metal behind the pulley top right:
Now, on the belt that works and is good
On the belt that was bought at the marine store.. no rounded corner showing, because the pulley is up so high it's blocking it.
I guess the question is, is 1.5 inches on a belt a huge amount that the adjustment can't overcome?
The idler pulley that they gave me based on the SN of the motor is part number 8M6500024 - does that make sense to pair that with belt 57-865615-Q03 ?
(Now that I look on the bill, the part ends in q03, but as shown in the picture the actual belt is stamped 003).
I guess the only possibility here is that it's the wrong idler pulley... but then why does your belt work fine with the same part number pulley...? I will again have to verify that I've done the tensioner correctly, although I did check this 3 times today.. Anyone have a part number for the larger one? I admit I didn't compare the two. Will also do that in the morning.
At the same time I noticed this today.. west marine will get about 200 bucks as soon as they open.. good start to their day! ( I tripped the breaker last week running 2 fridges, the built in one, an additional one, the burner, the micro, the tv, the ac , the battery charger and the hot water heater, all at the same time. while making breakfast )
